Results 1 to 3 of 3
Thread: bored throttle and MAF. tuning?
    ZIQ Guest
    Default bored throttle and MAF. tuning?
    recently i purchased a bored throttle body and a bored MAF meter. i installed the throttle body and the car ran alright except when i pull up to the lights etc it revs to about 2000 then drops back down to idle. When i installed the MAF however, the car wont idle properly. is a simple tuning all that is needed? if so where is a good place to go in western sydney?
    thanks for your help
    VX SS M6
    Jun 2005
    i think u may have to reset the idle air mixture to do it u take of the postive battery cable of for like 5 mins then recoonect start car hold the revs ova 2000rpm for about 25 sec see if that works
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    The problem may be in both items the idle holding sounds like there is a TPS problem, the maf thing is understandable, as its name suggestt it measures airflow into the engine, if you change the size of the hole the air is going through the calculations in the PCM are going to be incorrect. the standard unit will not limit performance in most situations so youre better off with the standard one.
    Berlina, the procedure you describe resets the idle air control... wont affect the mixture as it is controlled by the PCM
    Cheers Rob
  1. Fitting a bored out throttle body
    By 98vt-vy in forum V8 Development and Modification
    Last Post: 02-01-2008, 09:09 AM
  2. Bored Out Throttle Body
    By AdamAnt in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-09-2007, 07:51 PM
  3. Bored?
    By 253@7k in forum Jokes/Humour
    Last Post: 30-04-2006, 11:24 PM
  4. What did you pay?? (Bored)
    By Brodiee20 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2005, 10:32 PM
  5. Bored out throttle bodies
    By cuckoo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-04-2005, 10:49 PM
