Results 1 to 5 of 5
Thread: Vs-vt brake upgrade
    vs clubsport
    May 2010
    Default Vs-vt brake upgrade
    Has anyone upgraded their VS to the VT twin piston calipers and if so who did they buy them through? Am looking at an ebayer called "MR SPARES" from VIC who is selling them for around $500 with slotted rotors. And if anyone can advise me from experience or know of a solid sydney operator to purchase upgrade through would be a big help.
    VS-II Esteem
    Apr 2010
    Tasmania
    I found another ebayer that just sells recon'd VT twin-pot callipers for around $175. Might be the cheaper option to just buy those, get some brake pads, and bolt them up to your VS. I've been thinking of going that way myself. Might be cheaper than paying for stuff you might not need.
    Regards!
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    ....and you need to change the master cylinder and make some mods to make it fit onto the VS plastic booster.
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by RX25SE View Post
    Agreed,some people have posted on here about the problems theyve had after changing to VT calipers on their VS.The brake pedal ends up having to much travel and goes half way to the floor.Apparently the only way to fix it is to fit the VT master cylinder and brake booster along with the calipers.
    VZ AWD One Tonner
    Jul 2006
    The other way is to fit the VE calipers, which have smaller pistons, and work very well with pre-VT master cylinders. We've got full kits available here:
    VE Twin Piston Upgrade Package suit VB-VZ Commodore!!!
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
  1. VT BRAKE UPGRADE - looking for brake line adaptors for vh to vt
    By rusty05 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-12-2009, 02:54 PM
  2. VS brake upgrade.
    By VS_Pete_1 in forum General Discussion
    Last Post: 24-08-2009, 05:51 PM
  3. Brake upgrade
    By HamaTime™ in forum General
    Last Post: 17-07-2009, 04:24 PM
  4. Spongy Brake Pedal after VT Brake Upgrade
    By DJ Ice in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2008, 08:48 PM
  5. vp brake upgrade
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-11-2006, 05:55 AM
