Page 1 of 2 12 LastLast
Results 1 to 25 of 32
Thread: Top Gun 8mm leads, not letting gear change please help !
    FG XR6 TURBO /RIP VT II LS1 Clubby, VR Commodore S
    Mar 2009
    Default Top Gun 8mm leads, not letting gear change please help !
    i just bought top gun leads yesterday(8mm sprial wire) put them on car turned on
    everything was okay took for a drive, once it geared up it wouldnt come down after i stoped it was still in 2nd and i tried to drive around, it wouldnt gear up either ( i have a auto VR V6 btw)
    i put my old champion leads back on and everything was normal car was gearing up and down normally can anyone explain before i go to take them back today ??
    thanks in advance
    Beno1982 is offline Beno
    VX SS 5.7L M6 sedan
    Apr 2010
    Clermont
    I had to take the silver heat surrounds off the end of the spark leads, i had similar problem car ran like $%^&, took to mechanic removed those shrouds and ran fine after that, he said something about them earthing out not sure how true this can be i not real mechanically minded myself but give it a go, it worked on mine.
    Mar 2009
    silver heat surround ? on the leads ? hmm
    i dont see it ive got the red cable and the grey ends that goes onto the coil distributor and spark plug
    what exactly are the shrouds if you could try and explain thanks
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    on the engine side of the leads some have a metal casing around the outside of the connector
    Mar 2009
    im sorry im a little lost, so where the leads connect on the engine side, is that the coil pack your reffering to and the stand thing it sits on ?
    vs commodore
    Oct 2009
    Tamworth NSW
    All the V6 engines had them originally.Its to stop the exhaust manifold burning or melting the ends of the plug leads where they go onto the spark plug.Some aftermarket sets like bosch come with new heat shields.Or you can just fit the old ones again.
    Mar 2009
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    Quote Originally Posted by YILDI2 View Post
    sorry the end that connects to the spark plugs
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    so i wont be able to use the top gun leads ?
    if it's like the standard holden ones that i have they should just come off
    Mar 2009
    is there any chance of showing me in a picture if it isnt too much to ask for
    and mine is a VR maybe theres a difference since you have a VS ?
    thanks The1
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    i just pm.d you you box is full.got your chip returned to sender i had 4 as you address not 1 will have to repost it tomorrow for you
    Mar 2009
    Quote Originally Posted by Brett_jjj View Post
    does the heat sheild go round the boot of the leads the end that connects to the spark plug ?
    vs commodore
    Oct 2009
    Tamworth NSW
    Yes,they go over the boot at the spark plug end of the lead.
    Mar 2009
    i see soo in basic terms its my boot touching a metal surface that is causing the trouble ?
  15. #15
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    Just take the shields off, see if it makes a difference not having them on
    ________________________________________
  16. #16
    hsv91ss's Avatar
    hsv91ss is offline Holden4eva!
    VS Commodore SII
    Jun 2005
    Central Coast
    I have had the same thing, I just went back and exchanged for a pair without the shields.
  17. #17
    Mar 2009
    the pair i have just have the L shape boots doesnt have a heat shield on it
  18. #18
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    on THE ENGINE SIDE...........
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
  19. #19
    alexp36's Avatar
    alexp36 is offline Keep honkin-I'm reloading
    VR Executive
    Jan 2007
    When they say "on the engine side" they don't mean "on the side of the engine".
    - They mean at the end of the lead which connects to the spark plug.
    You would be able to tell at a glance if you had the shields on your leads. Sounds like you don't.
  20. #20
    Mar 2009
    thanks for the clear up Alexp36
    it doesnt have heat sheilds
    im just goin to return them and get sumthing average
  21. #21
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    I had the heat shields taken off my VS when they put the gas on and when it went for the next service the mechanic couldn't get them off so I had a go and it tore the lead end off, so he pulled the plug out and it had melted to the plug!!!!!!!!!! I'll always use the plug covers now.
  22. #22
    Mar 2009
    hye guys
    i had put my old leads back on couple days ago all was fine
    and then out of no were today it stoped changing gears just like what happen when i had the top guns on
    i found one boot of the lead that goes to the distrubutor coil was loose and didnt click on i tighten the end and then it was normal again
    went to work finished started driving home and out of no were again it stoped changning gears
    i drove home in 1st gear
    can anyone tell me if its a ignition coil related matter or its my auto ?
    my auto is a reco and ive only done 15,000ks in it
    thanks guys i would really appreciate any help
  23. #23
    VX SS 5.7L M6 sedan
    Apr 2010
    Clermont
    Have a look at your coil packs and check to make sure that there not damaged in any way. I also had a problem with my VS commodore. It sounded like it was only running on four cylinders and sure enough it was i found a big crack in the coil pack. I had no idea until i took to the mechanics and they pointed it out to me what the prob was, i searched that engine bay and did not see it, have a look at that and let us know.
  24. #24
    Mar 2009
    thanks for that Beno1982
    ill have a look around and see if i can see any cracks or so in my coil pack
    ill go to my mechanic when i get the chance on tuesday becuase monday is public holiday and let you guys know how it goes
  25. #25
    VX SS 5.7L M6 sedan
    Apr 2010
    Clermont
    As i said i searched that engine bay for problems, loose wires spark plug leads not connected properly kept going back to coil pack as i figured it was some sort of an ignition problem, the crack blended i still don't know how i missed it, once i got shown it stands out like dogs balls, i now run a MSD coil pack picked up off ebay for 200.
  1. I want to change my battery leads in VT, what do I need to consider before I start ?
    By itsme in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-01-2010, 04:33 PM
  2. Gear Change Auto
    By ufo8mycow in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-03-2009, 11:28 PM
  3. Automatic gear change
    By hN! in forum VY Holden Commodore (2002 - 2004)
    Last Post: 13-11-2008, 07:33 AM
  4. How do you change Ignition Leads
    By kaishiz in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-04-2008, 07:07 AM
  5. ute missing when idle plugs and leads change
    By willy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-12-2007, 06:26 PM
