Results 1 to 6 of 6
Thread: VR 3.8 Manual - Hard to drive \ noise
    1995 VRII V6 Executive 5 speed
    Sep 2005
    Default VR 3.8 Manual - Hard to drive \ noise
    Hey Guys,
    Got a little issue with my VR thats getting annoying, it runs fine and the clutch still bites strong, thought its hard to get a perfect shift at pretty much any Revs, unless i really nurse the clutch pedal out it basically bunny hops slighty, sometimes i can hear a quick metal sound at the end of the clutch path ..
    Uni joints ?
    My current Chariot - 1995 VRII V6 Executive 5 Speed
    95 VRII S pack 5 Speed Manual SOLD
    93 VP Sii 5 Speed Manual SOLD
    90 VN S pack 5 Speed Manual SOLD
    Sep 2005
    no gurus that can help a red lion brother out ?
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    gotta be something to do with the clutch/throwout bearing.Ive had mine out a couple of times and each time found the pilot bearing in the crank had loosened and spun.The last time I soaked it in oil for a couple of days and loctited it in.It had that shudder problem at take off the last time and a funny noise that happenned just at the end off the clutch travel.When I pulled it out the pressure plate fingers had a deep groove in it where the throwout bearing had been pushing on it and the noise was the outer race(which sits still) of throwout bearing contacting on the fingers and grinding them down.The clutch itself was from repco and from the wear in the plastic on the throwout bearing carrier it looked like the bearing retainer had worn too cocking the throwout bearing to one side as you loaded it up. The actual clutch linings and pressure plate face was perfect. I noticed the snout of the bearing retainer had a wear mark on one side ...bloke at the gearbox place said it was alright but now after consulting with mal wood I should have fixed it while it was out...kicking myself that I didnt.
    The new clutch is a stocko excedy item and it seemed to be really good at first but now its bed in ,the little shudder is back.I have got a new retainer and steel throwout bearing carrier from mal wood to put in now to hopefully address this problem.
    atm the clutch is a bit harder(only a little but you can notice it) to push in when the engine is running than when its turned off.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    93 commo with standard headaches.
    Jun 2010
    I had this problem with my Mazda ute, input shaft bearing was stuffed. I drove it for 9 years with that noise.
    'Ay no noething senor Basil' - Manuel the waiter.
    Beno1982 is offline Beno
    VX SS 5.7L M6 sedan
    Apr 2010
    Clermont
    I just converted my VS over from auto to manual and it cost me just under $1000 to replace the spigot bush. if this is what markovr is talkin about in his thread than to my knowledge from what my mechanic told me this is not meant to be loose in anyway, they said to me they had to lightly tap the spigot bush in to the back of the motor to keep it in tight, btw that $1000 included complete clutch kit thrust bearing and spigot bush inclusive of labour.
    Mine kept on making an annoying whistling noise and if you rested your foot on the clutch pedal or lifted the clutch pedal just slightly noise would disappear not sure if this is what your experiencing.
    Sep 2005
    Pretty close, its mainly shifting 1st to 2nd - if im at say 3500rpm 1st gear shifting up as soon as i push the clutch in it sorta feels like there is too much torque for the clutch to handle-very heavy pedal, the car jolts in a way, then after shifting when releasing the clutch even if i nurse it all the way to the end, it feels like its grabbing on still, like the revs still haven't dropped off in the change - go figure lol
  1. connect ps3 hard drive to pc??
    By vn_v6 in forum The Pub
    Last Post: 14-02-2010, 04:07 PM
  2. Noise from drive shaft manual VN
    By VnNz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-07-2009, 08:16 PM
  3. SATA Hard drive where do i get power from?
    By Pub247 in forum The LAN Lounge
    Last Post: 07-03-2009, 03:17 PM
  4. Help needed with IDE hard drive
    By sganro in forum The Pub
    Last Post: 07-04-2007, 04:11 AM
  5. Hard drive
    By tr3nt in forum The Pub
    Last Post: 24-11-2005, 04:19 PM
