Results 1 to 17 of 17
Thread: Need some advise on starting the ute...... Run out of fuel
    VS commodore ute series 3 V6
    Jun 2010
    Perth, Western Austraila
    Unhappy Need some advise on starting the ute...... Run out of fuel
    hey, Need some advise as i know now that my fuel gauage aint working properly
    I ran out of petrol and ended up a 20 litre fuel gerry to put it the ute and now it wont start,
    Is there anyone that may have any advise to get my ute started????
    Plus im thinking it maybe air in the line but most likely i could be wrong
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Does it crank over and just not fire up. May need to hold the starter on for a bit to fill the fuel lines. If doesn't fire up after 30 seconds then I would worry.
    Ronald Reagan (1986)
    Jun 2010
    Its cranking over, Tried it a couple of times , But nothing thinking i might of burnt the fuel pump??
    vn s pack 5spd/ vs calais S1
    Apr 2010
    yerpp u might hav burnt the fuel pump.. i rember wen i got my vn. it only ran on gas.. wudnt switch over to petrol... took out the fuel pump n it was all burnt, my cuz said because the car has been run on low fuel for awhile it burnt it out .. so yeh i think its dat lOl.
    also if it iz dat ..i think.. (think) i went wreckers n got another one from their for real cheap. cant remmber if i changed the seals n stuff :S lol
    Jun 2010
    Well leaving it over night at work, and see wat happens tomorrow got a fuel pump on stand by
    Apr 2010
    vt ss commodore
    Apr 2010
    when you turn your ignition on just before you crank it you should hear a faint buzzing sound coming from the back, that sound is the fuel pump pressurizing the lines, turn your key on and off about 5 or 6 times and that should give it enough juice to start it. if it dosnt make the buzzing sound at all then its definitly the fuel pump
    VS-II Esteem
    Apr 2010
    Tasmania
    w1war3na is right! but fully cranking the engine over shouldn't help as we're talking an electronic fuel pump and not a mechanical one. If you do what w1war3na said, all should be good. If not, your pump may be stuffed. Otherwise it could be something a lot more serious.
    Jun 2010
    Yeah tried turning the key and there is no faint buzzing sound there is nothing at all so im off to grab a fuel pump now... Just hoping it is just that
    VS-II Esteem
    Apr 2010
    Tasmania
    Yeah, it definately sounds like the fuel pump is buggered. With my VS, everytime i jump in and start it I don't just key the thing to crank it over. I've always stuck it on the ignition just before start so i can hear the fuel pump. It will buzz for a bit then stop. That's when i crank my engine over. I've always been like that. don't really know why. I guess i know she'll start up that little bit easier like that.
    I was also thinking, if it's not that there may be an in-line fuse that's blown. Unsure, but you'd have to do a little research. I can remember with the old VK commies they ran an in-line fuse. Used to blow out on most of em'. Once that happened there'd be no voltage getting to the pump and the car wouldn't start.
    Regards!
    vt ss commodore
    Apr 2010
    dont forget to sifen the petrol out before you remove the pump otherwise it could get dramatic
    VX Berlina S2 Gen 3 V8
    Feb 2010
    Echuca
    Check your fuel pump fuses and relays first, just in case. Would be a bitch to replace the fuel pump and still not have it work coz of a dead fuse. You could try the old "kick the fuel tank" routine to see if the pump has any go left in it.
    Apr 2010
    VY Ex-cop
    Mar 2006
    yep, u run a fuel injected car out of petrol, chances are your fuel pump will be stuffed, if its not it will be in a short time down the track sometime in the next few months.
  15. #15
    toyota lexcen - vr.
    Jan 2009
    victor harbor
  16. #16
    vr Commodore
    Aug 2006
    Same thing happened in my VR. It was the fuel pump.
    Never be afraid to try new things; remember amateurs build the ark while professionals build the Titanic.
  17. #17
    Super_Low 91's Avatar
    Super_Low 91 is offline ┌∩┐(◕_◕)┌∩┐
    Nimbus 2000
    Sep 2008
    Hogwarts
    my fuel pump died,, went out got a new one still wouldn start,, so i started checking everything i could think of an decided to disconnect the fuel filter an then turn the key on an off an it started spitting fuel out so then i reconnected the filter an went to start the car took a couple turns then is fired up,.. Im thinking i had air trapped in the fuel filter some how an yea once it was pushed out all was good,, Mite be something completely different but worth a try i guess
    Signature Goes Here
  1. fuel pump replaced, car still not starting
    By crewsy in forum V8 Development and Modification
    Last Post: 21-08-2009, 05:00 PM
  2. VL not starting after being low on fuel
    By OLDSKOOlRX2 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-08-2009, 07:14 PM
  3. VK 304 not starting (fuel pump?)
    By Pav in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-11-2008, 11:43 AM
  4. Noisey fuel pump... advise?
    By feistl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2008, 08:56 PM
  5. VT S Problems starting when i put fuel in...?
    By Swiftee in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-09-2006, 07:05 PM
