Results 1 to 3 of 3
Thread: trans fluid leaking
    rusty91's Avatar
    rusty91 is offline dopespec
    vs 5spd
    Aug 2008
    adelaide
    Default trans fluid leaking
    hey. i bought a vr berlina and the motor seized up after 4 days. i dropped another one in and had it running but the trans fluid starting pissing out. i found it it leaking out the top hose at the trans. so i went out a bought a second hand lines. to replace them they look like a **** of a spot to do. any tips from anyone?
    tivoom's Avatar
    tivoom is offline pimpin pizza wagon
    VR S2 Wagon
    Jan 2009
    newcastle
    pull the motor back out mate as they are a dog to do you could try pulling out the engine mount out and giving it a go but if they fails take it to a trans shop if you dont want to pull the motor out again hope this helps and i feel your pain ive done this twice and both times i pulled the motor out never again
    vr stroker v6
    Jan 2009
    townsville qld
    i replaced my tranny lines in my vn pissed the alloy pipes and went to pertic (a hydrolic place) and got some 2000 psi rubber line and fittings half hour to fit made life so much easer
  1. Leaking Red Fluid
    By stewee8805 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-03-2010, 10:52 PM
  2. leaking fluid
    By jake_h03 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-08-2009, 11:09 PM
  3. Car leaking a lot of trans fluid
    By VS_Wagon_Baby in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-11-2008, 10:39 PM
  4. Brake Fluid and Auto Trans Fluid.
    By Melchior3 in forum General
    Last Post: 20-02-2006, 11:49 AM
  5. Unexplained Leaking Of Trans/ps Fluid
    By ML3 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2004, 04:41 PM
