Results 1 to 15 of 15
Thread: VS V6 Transmission Problem
    VS V6 Exec
    Feb 2007
    Auckland, NZ
    Default VS V6 Transmission Problem
    I have a problem with the trans on my vs v6. There is no engine braking, ie when you are driving at say 40kmh and chop it into first. You can feel it go into first, but it wont engine brake, the revs just sit at just above idle and the vehicle just seems to roll. Everything else works perfectly, it just this. Anyone have any clues as too what this might be?
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    do you have an aftermarket exhaust? If the exhaust is to big for the engine there will be no backpressure.
    vt s s1
    Mar 2009
    when you say you feel it go into first wat do you mean?
    cos if its only idling it obviously isnt in 1st.
    why do you want to bang it in 1st at 40ks?
    cos if your box/ converter arent already rooted this is just a fast track to make sure it will be..
    yes engine braking may save your brakes but people never think that the cost of replacing brakes as to replacing a gearbox is quite a big difference.
    1998 vs s3 ute
    Jul 2009
    near blacktown
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    lol at exhaust backpressure, that wont make shit all difference....., and if your going to fast it wont drop to first, stop, put in first, rev out ten see if it engine brakes
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
    TrikkBen's Avatar
    TrikkBen is offline Compulsive.
    BNR32
    Apr 2009
    SE, Vic
    The rear spragg is broken. Just happened to me.
    If you put it into first and it seems to roll, if you put ur foot down will it free rev and then just engage... does it depend on what speed you are doing?
    Garantee its the Spragg, The cops were told to pull gears to save on pads and they used to break these all the time.
    The 4l60 and 4l60e are just weak as piss internally.... I'll post up a pic of a new spragg and my broken one...
    It's is effectively 2mm thick teeth slowing down the weight of the car, it's ridiculous...
    Ben
    There is no such thing as stupid questions, Only stupid people.
    VS V6 Exec
    Feb 2007
    Auckland, NZ
    TrikkBen, that is exactly the problem, a picture would be a great help, thanks alot.
    And for all other users I was only using the 1st gear as an example, I dont go around dropping it into first all the time..
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    A picture won't help you too much, the gearbox has to be taken out and given to a gearbox guy to fix.
    I'll get a pic up for ya's tommoro
    vs executive s1/ vz berlina
    Mar 2008
    Vr Berlina
    Jun 2009
    hey mate i had the same problem! i had to end up getting pretty much everything replaced in the trans.
    New clutch plates servos everything due to that breaking! Get it done before its too late!
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    Nothing else was wrong with mine when the spragg went, the teeth can't go anywhere they just hang around the area.
    Here is the pic.
    On the left is the broken one from my 4l60 (VN). On the right is a brand new one.
    The teeth on the right one you can see are what I was talking about. They are like 2mm think and have to slow down the whole car....
    Ben
    VS V6 Exec
    Feb 2007
    Auckland, NZ
    Thanks Ben, i see what you mean. Maybe a stupid question but i cant do anything about unitl about a months time, i dont care too much if i bugger others things in my trans, i just dont want it not being able to drive.. eg getting stuck in the middle of no where
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    Mine was fine for about 2 weeks and it went ****en bang and I lost all forward gears... So be careful....
    VS V6 Exec
    Feb 2007
    Auckland, NZ
    thats not what i want to hear haha. How many kms did you drive in those 2 weeks?
  15. #15
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    maybe 700-750
  1. VR Transmission Problem
    By CommodoreMan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-07-2009, 10:02 AM
  2. transmission problem
    By banjos in forum VE Holden Commodore (2006 - ?)
    Last Post: 12-06-2009, 05:59 PM
  3. Transmission Problem?
    By Acclaim96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-08-2008, 04:31 PM
  4. Transmission problem....i think...
    By Billo55 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-04-2007, 09:55 AM
  5. transmission problem with vn.help.
    By knighty in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-06-2005, 07:11 PM
