Results 1 to 7 of 7
Thread: low bcm to high bcm???? HELP
    puopoa is offline Antz
    BLACK 05 VZ SV6 6SP Manual
    Jan 2008
    Post low bcm to high bcm???? HELP
    wanting to install the remote boot release function in my VS.
    just wondering if this is a case of obtaining a high bcm + plus all the harnesses required for the bcm and then plug it all in appropriatley and have a working high bcm???? with of course the matched key head.
    i have a 97 vs acclaim which came with a low bcm which everyone says acclaims came with a mid bcm???
    Thanks
    VR Acclaim v6..?
    Feb 2008
    Gold Coast
    Not all acclaims came with a mid bcm, im 99% sure it depends on whether they had power windows or not as my car (VR acclaim) has power windows and a mid level bcm, whereas my mates car (VS s2 acclaim) has no power windows and a low bcm.
    Easiest way wud be to get an aftermarket alarm/immobiliser and get them to hook the boot release into that
    Jan 2008
    thanks, that would be the easiest way but i would like to have all buttons on same key rather than seperate.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Search is your friend........
    They are not interchangeable. The pinouts and loom are different. Low/mid has two plugs high/lux has four.
    1998 vs s3 ute
    Jul 2009
    near blacktown
    go get a new key with the boot release button on it then get a after market alarm as said and get it hooked up easier and added protection for your car and you will have the commodore key with the boot button all up cost you about 500 thats with the install
    VR Acclaim
    Jul 2005
    Quote Originally Posted by combatantsomeone View Post
    My VR Acclaim has no power windows, but it has a MID BCM!
    Perhaps the VR Acclaims had mid BCM, but in the VS they started to put low BCM into the Acclaim (unless it came with power windows)
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    I have a feeling that mid BCMs were the service item.
    May have been simpler for GM to stock only one type of BCM as a spare part.
    My guess is yours has been changed.
  1. Is 9.5:1 to high
    By eaton v8 in forum V8 Development and Modification
    Last Post: 29-12-2009, 10:53 PM
  2. Gen 3 High kms
    By VYIISSUTE in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 17-12-2009, 08:55 PM
  3. k's to high?
    By NVE_069 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-01-2009, 12:53 PM
  4. high pitch squeeling at high speed
    By pr0n in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-02-2008, 09:29 PM
  5. High pitch noise @ high rpm
    By Jesterarts in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-11-2007, 10:00 AM
Tags for this Thread
