Results 1 to 7 of 7
Thread: Servicing My VS Commodore! What should be done?
    VS-II Esteem
    Apr 2010
    Tasmania
    Default Servicing My VS Commodore! What should be done?
    Hey fellas,
    I've got a vs commodore automatic V6, and am wondering what should I do with the servicing as it's due for a full service. The water pump looks like it's on its way, as there's rusty colored water underneath it so i've purchased a new one which i will fit soon. I've also got some radiator flush "to get rid of the rusty stuff" and a new standard temp thermostat to suit as well as some coolant. Oils and filters need replacing as well as plugs and leads. The car's very original and bugger all has ever been replaced on it. I'm also doing the front brakes and discs along with the service.
    is there anything i've missed?
    Cheers!
    Rusty's Avatar
    Rusty is offline ٩(-̮̮̃•̃)۶
    304 Ute, WRX Impreza
    Mar 2010
    Queensland
    VY Ex-cop
    Mar 2006
    brake fluid, power steer fluid, trans service, hand brake linings check and adjust, lube door strikers, hinges. put the service sticker on window.
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    Quote Originally Posted by TheIceman View Post
    The most important, even if you do nothing else
    http://woteva.tk/
    If it ain't broke... I can break it for you
    toyota lexcen - vr.
    Jan 2009
    victor harbor
    air cleaner, diff oil, check rear main seal, brakes, check battery if its not maintence free. and check the steering rack for any leaks.
    only other thing i can think of is fill the radiator with oil and the sump with water...
    VS V6exec
    May 2010
    NSW sydney
    Quote Originally Posted by illusionalvr View Post
    lol i mite try that, see what the effect is :P
    S/C VN, VY SS, Waverunner GP1200
    Dec 2005
    S.A
    Replace fuel filter which are often forgotton as they under the car.
  1. VX Commodore Servicing and Other Items
    By Fonix in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-06-2010, 10:49 PM
  2. Self Servicing your Commodore
    By dtrain in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-03-2010, 08:43 AM
  3. Self servicing
    By rydogz in forum General Discussion
    Last Post: 21-07-2009, 07:08 PM
  4. Commodore Servicing in Brisbane?
    By Huthy in forum General
    Last Post: 08-02-2007, 07:53 AM
  5. VS Servicing
    By BlueBoy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-06-2005, 09:41 PM
