Results 1 to 6 of 6
Thread: VS hard to start ?
    woofer802 is offline Woofer 802
    VS Executive Stock
    Sep 2008
    Lightning Ridge
    Question VS hard to start ?
    HI, I have a stock vs which is hard to start cold & sometimes hot, I have replaced fuel pump battery & has been put on scan tool showed cam position censor, fixed problem for a short time but back to its old tricks, it has become a real pain just cranks over then starts as nothing is wrong, the light on the radio starts blinking red wile cranking which to me could be key reader, just grabbing at straws any ideas much apreached thanks
    Woofer.
    vt s s1
    Mar 2009
    so did you replace the cam sensor?
    sorry just bit hard to make sense of what you typed.
    if you could give a bit more detail as to what exactly it is doing when turning over and what not so we can get more info to help.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Try pressing the unlock button on the keyhead when the key is in the ignition - this should extinguish the red flashing light (which indicates the immobiliser is still on). Also check the metal ring around the keyhole - the metal tip on the keyhead must make good contact with this ring so as to turn the immobiliser off.
    Good Luck.
    VS Executive Stock
    Sep 2008
    Lightning Ridge
    Thanks for your reply's, First yes I did replace the cam sensor, OK at first but the problem has returned, tried what you said pushing the button no good same, the ring around the barrel is touching the key & bent it out a bit more to make a good contact just the same I am just about given up thanks Woofer.
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    if it runs rich, like blows black smoke, idles bad for a while, check injectors and fuel reg
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
    3.8 VS Executive Series 2
    Jul 2010
    Griffith
    hey, im just letting you know i sorta have/had the same problem, it only hard starts when its cold, but im not talking below 10 degree's either and has a new battery, new fuel management pump or some thing that holden replaced which didnt fix the problem, so i dont know what it could be personally, the key contact ive heard of could be an issue but its not mine, and plus i have a new key so it isnt that. anyway the posts have gave me a bit of an idea.
  1. Hard to start?
    By ElDubya in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2008, 11:15 AM
  2. VT is hard to start
    By grassy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-09-2006, 08:41 PM
  3. Hard to start
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-11-2005, 04:02 PM
  4. hard to start!!!
    By dahlyla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-08-2005, 02:24 PM
  5. vn hard to start
    By stilly in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-04-2005, 09:38 AM
