Results 1 to 23 of 23
Thread: 304 won't start after doing Dizzy Cap/Leads/plugs/button
    Deneo's Avatar
    Deneo is offline Lock your Daughters up
    VS HSV Statesman
    Dec 2009
    Western Suburbs
    Default 304 won't start after doing Dizzy Cap/Leads/plugs/button
    hey guys
    Brought all new shit to refurbish the stato.
    Changed everything, NGK leads and Plugs and Bosch Cap and rotor button.
    Got it all back together and now it won't fire.
    Iv'e got Fuel, Spark and am 99% sure the order is right on the dizzy cap because i copied it off a diagram i found on here. Dizzy cap is seated right, It just won't start!
    Iv'e tried moving all the leads around to compensate for the fact i might of read the diagram wrong but it still won't start!
    I'm getting a very funny unburnt fuel smell aswell.
    Any help would be GREATLY appreciated as i'm stumped and everyone else i know is aswell.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Don't quote me, but I remember reading on here that the online diagram is not always correct because sometimes the distributor is reinstalled in a different position and then the mechanic re-arranges the leads to suit.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    Quote Originally Posted by hako View Post
    to check this, wind the motor over till no. 1 at top dead centre, marks on the ballancer. than check were the rotor is pointing.
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
    VY Ex-cop
    Mar 2006
    sure you remembered to put the rotor in and seated correctly?? ive done this many of times and wondered why things wont start.
    VX II Calais LS1
    Jan 2010
    as moff_man says crank the motor over by hand until cyl No 1 is at TDC then look where the rotor is pointing, put lead number 1 to the same point on the dizzy cap then put each lead on in turn in the correct firing order. you dizzy may be out 180
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost.
    vs commodore
    Oct 2009
    Tamworth NSW
    You cant just put the number 1 cylinder at top dead centre,it has to be on the firing stroke as well.All you have to do is remove sparkplug number 1, and get someone to wind over the engine by hand,(use a spanner or socket), while you seal your finger over the sparkplug hole,when the piston is on the compression stroke it will force air past your finger,this is the compression stroke for the number 1 cylinder.Then slowly turn it over in the same direction,again by hand, and then stop it on TDC (Top Dead Centre)on the timing marks.If you go past this point,you will have to go around a couple of times again to get to the compression stroke again on that cylinder.Once this has been done,you can set the distributor to fire on the number 1 cylinder.If you try to set it without the number 1 cylinder on the compression stroke,it will be trying to fire on the inlet or exhaust stroke instead.
    Deneo's Avatar
    VS HSV Statesman
    Dec 2009
    Western Suburbs
    vs commodore
    Oct 2009
    Tamworth NSW
    Deneo's Avatar
    VS HSV Statesman
    Dec 2009
    Western Suburbs
    Okay guys.
    Been out there working on it for a few hours thismorning.
    got it to TDC and the rotor button ties in with the diagram that i was following. Anyway reassembled.. Made sure the dizzy cap was seated nice and shit like that.
    Tried to start it again, sounded like it wanted to fire about 3 times then went back to turning over with nothing at all.
    I'm f'n stumped and frustrated haha. iv'e got 13k's to empty so i'm assuming i have fuel. Anyone else have any ideas?
    Thanks, Deneo.
    vq statesman s2 5l
    Jun 2010
    Deneo's Avatar
    VS HSV Statesman
    Dec 2009
    Western Suburbs
    vs commodore
    Oct 2009
    Tamworth NSW
    Did you remove the sparkplug and find the compression stroke for number 1 cylinder?
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    try the old coil pack again.
    A mates Calais did this, and it ended up being a dodgy coil. Even just check all the wires are attatch properly.
    Deneo's Avatar
    VS HSV Statesman
    Dec 2009
    Western Suburbs
    vs commodore
    Oct 2009
    Tamworth NSW
    Once its set to TDC on the compression stroke of no 1 cylinder,all you have to do is look at which plug lead terminal on the dizzy cap the distributor rotor is pointing to , and put the number 1 plug lead to that terminal.Then follow the firing order of the engine from that one for each plug lead in the direction the dizzy spins...
  16. #16
    Deneo's Avatar
    VS HSV Statesman
    Dec 2009
    Western Suburbs
    Iv'e done that..... followed the order off the front of the manifold.. Iv'e pulled leads off and put a plug in them and they are sparking.... I'm stumped.
  17. #17
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    When my Calais was rebuilt they had problems getting it to fire. Turned out to be a faulty rotor button.
  18. #18
    moff_man's Avatar
    Nov 2008
  19. #19
    vz wagon
    Aug 2006
    Wild west of Melb
    Quote Originally Posted by Deneo View Post
    Is it getting fuel and is it alot of spark ? why did you take the dizzy out ?
  20. #20
    Deneo's Avatar
    VS HSV Statesman
    Dec 2009
    Western Suburbs
    seems to be alot of spark, Got my mate to hold the plug and lead haha. and i'm pretty sure it's getting fuel, how can i check without taking the pressed on clamps on the fuel rail? I didn't take the dizzy out, Just replaced the cap.
  21. #21
    VX II Calais LS1
    Jan 2010
    spray some "start ya bastard" in the throttle body.. if it fires for a few seconds you know its fuel related problem
  22. #22
    Aug 2004
  23. #23
    Deneo's Avatar
    VS HSV Statesman
    Dec 2009
    Western Suburbs
    yeah it is! All sorted, went out one morning rolled it down the driveway, tried to start it and bang. I'm assuming i was hell low on fuel.
    Thanks for al lthe replies guys!
  1. VK 5l dizzy cap wearing out and leads come loose, break
    By megabuff in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-06-2009, 07:27 PM
  2. how much is a dizzy cap n rotar button?
    By LethalVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-02-2007, 03:56 PM
  3. Vr V8 Cap & Dizzy leads replacement
    By dinodog in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2006, 11:44 PM
  4. Dizzy & Rotor button
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-08-2006, 09:21 PM
  5. Plugs and leads
    By SS57 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-10-2005, 11:06 AM
