looking at putting an 8 in my VR cause the 6 is almost dead what do i need for it?? and can i still use the T5 box?? i know i have to change computers and everything and a LSD diff should be fine and the woring harness but is there anything else??
thanks guys![]()
mmm loving my VR
crap sounds like a bit of work was gonna upgrade the brakes regardless of if i put an 8 in or not how much am i looking at for everything??
mmm loving my VR
best to find a wreck. thats would be the cheepest option
Originally Posted by Adam Savage (mythbusters)
yeah was thinking that now debating whether to rebluid and spercharge the v6 or just do the v8 decision decisions haha
mmm loving my VR
I'm pretty much in the same boat, except my VR probably still has about 100k kms left in it.
to supercharge or surcharge the cc's.
what are LS1's worth ?
My current Chariot - 1995 VRII V6 Executive 5 Speed
95 VRII S pack 5 Speed Manual SOLD
93 VP Sii 5 Speed Manual SOLD
90 VN S pack 5 Speed Manual SOLD
i was thinking ive im gonna do the v8 put an LS1 in it my VR only has 167k kms on it but its been flogged by the previous owner and i have a knock at the back and the lifter tap as well
mmm loving my VR
VR V6 and V8 brakes are the same, only different from VP S1 back and then VT onwards?
You can use a V6 box if you get a V8 T5 input shaft and bellhousing. (there on ebay every now and then)
Dont forget the new clutch and flywheel for the V8 motor. (can get new or ebay for the flywheel)
Tailshafts im not sure, you wouldnt think the V8 gearbox sits any further back then a V6 box cause it still goes through the same hole in the floor so a educated guess would be they are the same.
Check out savages ride in the VN/VP sections, his got a LS1 in his Vn now![]()
The Daily VN T5V6
355 VN GRP A REP
thanks heaps for that info mischa
mmm loving my VR
V6 and V8 box's are different in more ways then just input shaft and bellhousing. Input shaft in a v6 is 35mm longer( and u can't just change the input shaft as it had more teeth on it inside the actual gearbox), bellhousing, gear ratios, and i have heard that v8's gear set is shot pinned.. but i cannot confirm this, and also you'd need a v8 fly wheel and clutch assembly.
finally im not sure if the output splines to the tailshaft are the same?
Hmm, i didnt know about the inside of the input shaft being different other then ratios? Ive also always been told the gears are the same by gearbox rebuilders to the V6 other then the ratios.
Ive had the V6 T5 and V8 one next to each other and the outputs looked the same but without the tailshafts to test you never know....
The Daily VN T5V6
355 VN GRP A REP
