Results 1 to 18 of 18
Thread: VS Clubsport stops while driving
    VZ HSV Senator, VL calais RB25 turbo
    May 2010
    Norsey
    Default VS Clubsport stops while driving
    hey guys got a probem with my sisters car. The car runs fine and will idle for hours but once you drive it for half a hour or so it stops, but once it cools down alittle it starts again then stops again. i've replaced the (coil,ignition module,brand new keys) i've also had the computer on it but i think the guys was unsure what he was doing, really starting to pull my hair out. if you could help it would be appreciated. thanks.
    joe
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    common with a crank angle sensor issue, which is in the dizzy in this one and is a hall effect sensor type
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
    May 2010
    Norsey
    yea i thought it was that. my brother in law wrote that. he thought it was located near a pulley or somethin. theres one on ebay for 15 bucks. ill tell him to get it. thanks for that. is it easy to install? never done it before.. thanks again
    Jun 2005
    Before you waste your money, its not a crank angle sensor. They are only on a V6
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    May 2010
    Norsey
    the filters alright. maybe the pump. but it only cuts out after you drive for 10mins or so. idles for ages
    VY Ex-cop
    Mar 2006
    if you can get a can of freeze spray, when it plays up, shoot the dizzy. you have to pull the dizzy out from memory to replace the module thats in it. thats probably your issue though if you've done the ignition module.
    May 2010
    Norsey
    VX II Calais LS1
    Jan 2010
    Hall effect sensor for sure get a new bosch dizzy... the sensor is built in to the dizzy. You can replace it if you are confident in taking the distributor apart, easier and quicker to get a new dizzy
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost.
    May 2010
    Norsey
    May 2010
    Norsey
    could it be the ignition module, or something to do with that. apparently it wasn't changed but one from a mates car (who has no problem) was tested in it but it got really hot just like hers does. in my mates car it works fine. what could cause this? also my brother in law sprayed freeze spray on another sensor near the oil pump when it died then it started straight away.. does any one know what this sensor is? i willl have more info on it tommorrow. thanks guys.
    P.S. Ill try get some pics of it on here for yous to look at. pretty awesome for a pink car lol
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    crank angle sensor = one near the oil pump
    pretty sure, never done one on a tank engine
    ^^^^^WRONG do not learn from this post
    WTB: mulberry VN interior parts
    VY Ex-cop
    Mar 2006
    Quote Originally Posted by savage1987 View Post
    crank angle sensor in V8 is in the dizzy, not the front of engine.
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
  15. #15
    Jun 2005
    Quote Originally Posted by TheIceman View Post
    Except that its not called a crank angle sensor, its a hall effect sensor in the dizzy
  16. #16
    May 2010
    Norsey
    Now we have no spark at the dizzy and a new coil is in? What else could cause that? still need to check the other side of the coil to see if theres spark there.
  17. #17
    VS ute 5lt
    Sep 2008
    Moranbah
    hey champ i got a vs ute with a 5Lt in it. i had the same problem n i went through the same stuff as u n i found that it was the thermostat.
    i couldnt belive it myself but yer.
    have fun :P
  18. #18
    May 2010
    Norsey
    nah this is runnin without one, already thought about that. think a dyno is the way do go
LinkBacks (?)
  1. Car just stops
    By greg644 in forum Electrical Wiring / Questions
    Last Post: 10-11-2011, 08:44 PM
  2. just stops????
    By ianf in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-05-2009, 12:22 PM
  3. stops when driving along
    By DAROKA in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2006, 11:01 AM
