Results 1 to 10 of 10
Thread: power steering
    benno9911's Avatar
    benno9911 is offline Donating Member
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    Default power steering
    how much oil dose the oil system take to fill
    VS V6exec
    May 2010
    NSW sydney
    Quote Originally Posted by benno9911 View Post
    hey? you dont really need to know that and i dont know the answer ,just fill it up till it reaches its max level turn the wheels couple times with the lid off and the fluid level will drop abit then just re-top it up to the correct level its got "max and empty" on the side of the it or somthing like that.
    cheers
    lance
    benno9911's Avatar
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    Cause I have filled it up like 3 tims I think I need a new power steering rack
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Well is there a pool of PS fluid over the ground?
    Mine used to leak out the bottom of the reservoir and you could tell cause it would get on the belt and wip it onto the under side of the bonnet.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    benno9911's Avatar
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    well its been pissing down ran here no stop so the best i can do is tell you that under the driver side of the car there is the colors you get when you put oil on the ground in water
    vs commodore
    Oct 2009
    Tamworth NSW
    VS power steering system holds approximately 700 ml's of dexron 111 (3) type auto transmission fluid.
    VY Ex-cop
    Mar 2006
    best bet, take it to local servo and steam clean around the power steering area, pump, rack and get it clean. start engine, turn wheels lock to lock several times and look for new tranny fluid running from somewhere. normal places it will leak from are:
    1.the top of the rack where the steering shaft goes in to it - easy fixed for a few bucks.
    2.the reserviour 'o' ring - easy fixed for a few bucks
    3.the power steer pump front pulley seal - easy fixed for a few bucks
    4.the rear of the pump large plug 'o' ring - easy fixed for a few bucks
    5.return hose to reserviour - replace hose or tighten clamp - easy fixed for a few bucks
    6.split high pressure hose - easy fixed for about $70 or so
    7.internal rack seals and is leaking from the rack boots - terminal rack problem, cost a few hundred bucks to fix to replace rack and alignment
    all up, easy system to work on and diagnose and fix.
    benno9911's Avatar
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    it was
    i was taking it for a long drive the outer night and started to smell burning oil it was a dodgy o ring
    VY Ex-cop
    Mar 2006
    benno9911's Avatar
    03 VY S2 Exec
    Jan 2010
    Warrnambool
    well not 100% sure there was a couple of oil drops under the car but i think it might be just might be from when i fixed it
  1. Power versus non-power steering columns?
    By BaggedVL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-10-2009, 06:19 AM
  2. Replies: 1
    Last Post: 09-11-2008, 09:18 AM
  3. VH Power Steering..Trade For Manual Steering
    By vasrox in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-10-2008, 12:23 PM
  4. oil line from power steering to steering rack
    By onmy6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-12-2007, 10:08 AM
  5. VH Power Steering..Trade For Manual Steering
    By vasrox in forum Swap / Wanted to Buy / Trade
    Last Post: 28-01-2007, 02:29 PM
