hey guys my car has overheatd on the way home from work ferther inspection no water in the radiator my fault i didnt top it up after work. pulled in at my mums work filled it up all seemed well but my gauge keeps rising ive done some reasearch and the problem seems like it could be my thermostat or my radiator is blocked any ideas ? has anyone else had these problems all help will be much appreciated
My vz ssz ute
THOSE WHO CRITICIZE OUR GENERATION FORGET WHO RAISED IT
find out where the coolent went first place than how much damage may of been done.
Originally Posted by Adam Savage (mythbusters)
haha yeah probley shouldve mentioned im a panel beater and i crashed my front end fixed it and put a second hand radiator in with very little or no coolant in it sooo yeah ill have a better look at it tomorrow
My vz ssz ute
Exactly right check for leaks and fix them and plain water on it's own is no good adding it will over time dilute the coolant and it wil be ineffective as a coolant and a corrosion inhibitor.
I'd also be checking if you have any air trapped in the system by bleeding the cooling system.
give the system a good flush/bleed this should be done everytime you change the coolant IMO especially after putting a new radiator in. still persists, check for airlocks or any blockages and check your radiator cap is sealing properly as well. if its still continuing you could have a screwed water pump or thermostat or worse.
Keeping the correct fluids eg: coolant/water/oils in a car and checking them regularly is ESSENTIAL for longevity and reliability in the future.
