Results 1 to 3 of 3
Thread: Changing IRS cradle
    Jun 2005
    Default Changing IRS cradle
    So I have to replace my cradle. Anyone got any tips to help me out if they've done it? Where should I jack it up from and put jack stands, as I usually jack up from the diff, and put stands under some part of the IRS assembly.
    Also, I've been told I should replace the cradle bushes with some nolathane bushes. Should I do this, and what are these normally worth?
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    the last time i had to remove the rear end assembly i had the VS on a hoist, but it can be done on stands you just have limited room to move and jiggle things about.
    place your stands just infront of the IRS arm where it pivots, theres a good flat jack location. rubber vs nolathane in the rear end, i have no idea, dont really know how it'll feel with i just went rubber again. i know that generally rubber lasts.
    vx clubsport r8
    Mar 2010
    if you have some spare crapy rims around they make good stable stands that will give you heaps more room to work under there.
  1. Vs irs into vt cradle
    By anzac in forum VT - VX - VU - WH - V2
    Last Post: 17-09-2008, 08:48 PM
  2. f.s: vr-vs irs cradle
    By SNAFFLER in forum Parts And Other Items For Sale
    Last Post: 29-08-2007, 11:47 PM
  3. f.s: vr-vs irs cradle
    Last Post: 05-04-2007, 03:45 PM
  4. Wtb In Sa Diff Cradle
    By PRO AERO in forum Swap / Wanted to Buy / Trade
    Last Post: 07-11-2006, 07:13 PM
  5. VR/S IRS cradle
    By urmyho in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-08-2006, 03:55 PM
