Results 1 to 2 of 2
Thread: Vs Acclaim IRS Rear Chassis Points
    Vs Acclaim
    Jul 2009
    Question Vs Acclaim IRS Rear Chassis Points
    Hi guys and girls do you know where the rear chassis points are on a 1996 Holden Acclaim v6 with IRS?
    I am a little worried because their car manual shows me were the chassis points are, but dosen't look strong. Is the chassis point underneath a large bolt, almost halfway between the rear tyre and the centre jacking point?
    I want to use chassis stands, never done it before
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Only thing I can suggest is you use the trolley jack locations as per the attached pix (IRS is on left). Apologies for quality of pix.
    Attached Thumbnails Attached Thumbnails Vs Acclaim IRS Rear Chassis Points-trolley.jpg
  1. VY ACCLAIM REAR >> VZ EXEC / BERLINA REAR or something of the sort??
    By josh.meaden in forum VY Holden Commodore (2002 - 2004)
    Last Post: 13-03-2009, 09:56 PM
  2. Rear Jack points on Vp vacationer.....
    By Cobez in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-12-2007, 08:11 PM
  3. Vp Vacationer Jack Points Rear???
    Last Post: 18-10-2007, 08:47 PM
  4. Is the VIN or chassis number stamped on the actual chassis ?
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-12-2005, 08:49 PM
