Results 1 to 7 of 7
Thread: VS Is stalling from reverse to drive?? Help
    VR Acclaim 3.8L
    Dec 2009
    Default VS Is stalling from reverse to drive?? Help
    I have a vy engine in a vs commodore, and when i reverse my car out the driveway and when i put it in to drive , the car stalls and the scary thing is that its an auto v6 lol? What can be that problem?
    And when i turn my steering wheel ,my whole car shakes??
    VR Acclaim
    Sep 2008
    Kingsley WA
    The throttle body and the Idle Air Control valve may need cleaning. The engine idle is raised when reverse is selected to prevent stalling. If the IAC valve is dirty idle speed will not rise and stalling occurs. I suggest you disassemble the throttle body and IAC valve and clean it with a throttle body cleaning agent.
    vs commodore
    Oct 2009
    Tamworth NSW
    It can also be the sign of a vacuum leak if the IAC cant control the idle properly.Its worth checking the vacuum lines around the engine and the vacuum reserve tank under the left front guard.This reserve tank looks like a black plastic ball looking thing, and is supposed to have a vacuum line connected to it.Sometimes the vacuum line can come off.If you have problems with the heater in your car not changing from feet to screen or vice versa,that can be another sign that there is a vacuum leak.But as mentioned above, most of the time with stalling or idling problems, the IAC valve and its passage in the throttle body can just need a good cleanout.
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    my vn does that same, and when its hot the idle hunts, up and down, stalls when i turn to park at low speeds full lock,does my head in
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
    VY Ex-cop
    Mar 2006
    Quote Originally Posted by vn_v6 View Post
    same pull throttle body and clean, dismantle IAC valve, clean, lube with graphite powder make sure it operates smoothly, replace, reset base idle speed.
    problem solved, next...
    VR Acclaim 3.8L
    Dec 2009
    sweet thanks boys.. what about when i have my foot on the brake, the whole car vibrates, and shakes just a tiny bit?? and when my foot in on brake while i turn steering wheel, it shakes alot!
    VY Ex-cop
    Mar 2006
    check brake booster for vacuum leak, maybe a split diaphram in the booster causing crap idle and air leak when you got foot on it. and turning steering wheel indicates IAC maybe not opening up to compensate for increased engine load.
  1. Reverse into drive. Is this a problem??
    By Kiifu in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-03-2010, 06:36 AM
  2. VR auto stalling in reverse
    By nathg in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2008, 06:58 PM
  3. Stalling (auto V6) when changing from reverse to drive. Help!
    By pugga in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-01-2008, 07:32 PM
  4. Is this normal? Reverse Stalling
    By kurtbarker in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-06-2005, 11:15 PM
  5. Reverse Stalling in VR
    By RVN 355 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-03-2005, 09:43 PM
Tags for this Thread
