Results 1 to 9 of 9
Thread: resetting base idle
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    Default resetting base idle
    quick question. does anyone know how to reset the base idle on a vs v6? i use the tech 1 but i don't have the luxury this time.
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    VP Exec
    Jun 2005
    There are very few reasons why you should have to adjust the base idle - only engine mods, otherwise fixing whatever it is that is causing the low base idle speed is preferable.
    Clean the throttle body and IAC valve pintle first. Do not use carb. clean for this! (Use kerosene and a cloth.)
    If you insist try:
    Mark the current position of the idle stop screw so you can get back to where you started if you change your mind.
    Engine at operating temp., accessories and cooling fan off, park or neutral.
    Create a vacuum leak sufficient to cause the PCM to completely close the IAC valve eg. pull the line to the brake booster.
    Disconnect the connector to the IAC motor to lock it in the closed position and refit the vacuum hose.
    Bridge the diagnostic connector terminals, same as checking for codes, to lock the igntion timing.
    The base idle speed should be 450-550rpm. The engine will nearly stall at this speed.
    VY Ex-cop
    Mar 2006
    Quote Originally Posted by wraith View Post
    3000 RPM for 10 seconds.
    no, this is not how you reset base idle.
    04 VY Exec SII
    Sep 2009
    Sydney West Side
    When I start my VS it idles to 1600 then slowly falls for about 5sec back to 900. Is that normal? 158000kms on the odo.
    vs commodore
    Oct 2009
    Tamworth NSW
    In the VS manual is says-Make sure the IAC and its ports in the throttle body are clean .Ensure the throttle valve moves freely and returns to fully closed position.Run the engine until its reached operating temperature.While the engine is idling,ensure the engine cooling fan and all accessories are off. Disconnect the wiring from the IAC valve at the same time the ignition is switched off.Open the throttle slightly and start the engine.After the engine starts,slowly allow the throttle to close.If the engine stalls,adjust the base idle screw one half turn and start the engine again.After the engine has been idling for 2 minutes,check the base idle speed ensuring the engine cooling fan is off.If the base idle speed is not 500-600 RPM,adjust the base idle screw to achieve a base idle speed of 450-550 RPM.Stop the engine and connect the wiring connector to the IAC valve.Start the engine and after 5 seconds check that the idle speed is to specifications.Hope this helps.
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    moff_man's Avatar
    Nov 2008
    thanks guys, but its seems to be a lazy iac, or a crook coolent temp sensor. the iac is very noisy and it idles very high hot or cold for 30sec, once started also injectors and t/b have been replaced and cleaned
    VS II
    Aug 2010
    Hi Moff did you end up sorting this out?
  1. Looking for haltech base map vn v6
    By needwork2-4fillhabbit in forum Tuning
    Last Post: 29-10-2009, 06:28 PM
  2. Resetting the Idle Speed on a Black EFI.
    By '88 VN Custom in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-10-2009, 05:14 PM
  3. V6 Base Idle Reset
    By convas in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-04-2008, 08:15 AM
  4. vx base idle set/reset?
    By Leanne in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-03-2008, 09:19 PM
  5. base idle
    By daniel VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2006, 02:28 PM
