Results 1 to 12 of 12
Thread: Frustrating Gear Change Problem.
    GetToDaChopa is offline Blues Brother # 2
    The Blues Mobile
    Dec 2008
    Western Sydney
    Default Frustrating Gear Change Problem.
    Umpa loompa dumpady doo, i have another ridle for you... My car has been having a really bad issue. It changes gears so bad that i start crying and need a tissue. Ok.
    Its a VR Automatic. Now you have to remember this problem is intermittent, so one day i could be driving fine one day, and it could be playing up the next. This has become very frustrating.
    What happens is that it revs very high before changing gears. But. The gearbox apparently has been checked and there was no issues found with it. Although i keep getting the TPS (throttle possition sensor) error very often. The sensor has been replaced, but seems to have gotten even worse. Before i could turn the car of and start it again and it would drive reasonably, now i could have the car off for 3 hours and get the same issue.
    So i'm wondering what your thoughts are on this problem and what else it could be. Ask if you need more information.
    VY Ex-cop
    Mar 2006
    wires to TPS connected ok?? is the TPS been set up correctly? check it out for correct setting.
    The Blues Mobile
    Dec 2008
    Western Sydney
    Quote Originally Posted by TheIceman View Post
    How do i check it for a "correct" setting?
    vs commodore
    Oct 2009
    Tamworth NSW
    Ive only got a VP manual but it might be the same,Im not sure. It says - with the throttle valve in the fully closed position,install the TPS onto the throttle shaft at a position 30 degrees clockwise past the throttle position sensor retaining screw holes in the throttle body.Align the holes in the TPS with those in the throttle body,install the retaining screws.
    The Blues Mobile
    Dec 2008
    Western Sydney
    Quote Originally Posted by Brett_jjj View Post
    Would that though cause it run beautifully one moment and fail the next, thats the thing, it ran awesome for a whole week and now its on and off.
    VY Ex-cop
    Mar 2006
    check for smooth operation with multimeter. check setting with specs, i dont have any in front of me but im sure you can find them somewhere here.
    get ya multimeter onto it.
    VR Ute
    Jan 2010
    Check the little tiny rubber spacer on the end of the TPS, it invariably falls out if you change the TPS with the throttle body on the car, and if you are not aware of it, you will put the new one in without it and the car will run just as bad as if you never changed it at all. Its a tiny little sucker, easy to miss, but makes a huge difference. Also check the VSS, if that is faulty, it can cause shifting problems as well. The VSS and the TPS work together to tell the gearbox when to change . Hope this helps.
    stugdum
    The Blues Mobile
    Dec 2008
    Western Sydney
    Alright i'll take a look, anyone have a picture or a diagram :/ i had a mechanic change the TPS, im sure he would have done it right the first time, but since then it might have gone wrong.
    hq-racing's Avatar
    hq-racing is offline HSVR-28
    93 VR CLUBSPORT WAGON DAILY. 73 HQ PREMIER PROJECT
    Sep 2008
    S.A
    Quote Originally Posted by Stugdum View Post
    stugdum
    VSS? silly question but what is that?
    VR CLUBSPORT WAGON
    yes a clubsport wagon....
    LIVE THE DREAM
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    Quote Originally Posted by hq-racing View Post
    Vehicle Speed Sensor
    The Blues Mobile
    Dec 2008
    Western Sydney
    VR Ute
    Jan 2010
    I dont have pictures but the VSS is located right at the back of the transmission and is easily identified by the wires going to it. It is usually very simple to remove and replace.
    stugdum
  1. Frustrating HDD install problem!
    By azzfox in forum The LAN Lounge
    Last Post: 29-03-2010, 05:17 PM
  2. Frustrating Stalling Problem
    By seraphic06 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-12-2009, 02:29 PM
  3. weird transmision gear change problem!
    By mrVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-10-2009, 08:52 PM
  4. help how do i change gear shift
    By whatsdown in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-04-2009, 04:00 AM
  5. diff gear change
    By V6VL in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-02-2006, 06:46 PM
