im from the US and am swaping the 3800 from a 99 camaro into my 80, i recently have been looking for a new bracket to hold the AC compressor and realized that the Holden 3800s have what appear to be perfect placement, was wondering if anyone had pictures of the front of the motor with all the accessories on it, thanks for your time
dont know what car this is but im looking for more pics with this one http://gmv6.org/gallery/S10_3800_Swa...ay7%28M%29.jpg it looks like the AC would go above the oil filter rather then next to as it is in my camaro
looking now.......
This is the best I have on my lap top. VN - Engine number 190 from 1988.
and 3 Dangerous non ABS VN's
thanks for lookingnot what i was looking for tho at least doesn't look like it was looking for http://gmv6.org/gallery/S10_3800_Swa...ay7%28M%29.jpg but i don't see the AC on it anyone know what car that motors from it looks like the AC would go above the oil filter idk tho thanks again
and no we don't all wear ties when we take engines out.
this motor thanks for your quick reply but so far this is the only pic i could find it looks like the ac goes on top of the oil filter not sure thanks tho again green
no it showed up that wasnt the motor i was looking for tho (gmv6.org/gallery/S10_3800_Swap/engineBay7%28M%29.jpg) the one im looking for idk how to link it from google images
ok it worked i tihnk you just hafta copy paste
Just put that link in it worked...
Yep above the oil filter by the look of it.
The power steering pump is above the oil filter. the A/C is on the lower right of the picture - the driver's side for you. It's worth pointing out that the pic is of an early Commodore V6, I think you would call it a series 1. 1999 will be our Ecotec - from 1995-2003 (I think) here. The power steering pump is mounted lower down on them I think but the A/C will be in the same place.
do you know which motor that is by chance? it looks almost the same as the ones in the camaro but the ac is moved and if i had that braket my swap would be so much smoother
No - I cant tell what the motor is in your photo.
ok thank you for your time if you happen to come across one anytime a pic and name and what not would be much appreciated thanks for your time
idk the motor i have up looks to me like a 3800 Series two (GM motor) with a different braket but i was told it was a holden 3800 dont know what one tho
Looks like Ecotec with the US spec. inlet manifold. Look familiar?
http://gallery.oldholden.com/d/318405-2/102_6668.JPG
no that one has the AC on the drivers side low, thanks tho, i think the one i want is the one with the suprecharger on it m90 i believe not 100% sure tho
here is the motor in the pic you supplied took some digging to get this pic though lol http://www.gmv6.org/images/L36.jpg
ok after some further digging here is the motor your looking for hope this helps its out of a 2002 camaro or firebird the motor is a L36 anywayz atatched a pic for you http://www.zorly.com/images_camaro/g...V6%20(L36).jpg
thank you very much i appreciate your help
no problem hope all goes well with the conversion
