Results 1 to 6 of 6
Thread: vs berlina fuel question. got me stumped.
    vs berlina s2
    Feb 2009
    Default vs berlina fuel question. got me stumped.
    okay guys. 1997 vs 2 berlina fill the tank up to the brim. after 44 litres the gauge shows empty and the distantce to empty is fairly low...it has a tow pack but weather that makes a difference to tank size or not? and how could i go about the car to tell me its low on fuel when it really is?
    VP Exec
    Jun 2005
    It's possibly the sender unit inside the tank. They have a variable resistor that has a sliding contact operated by a float. The contact wears in one area and the gauge reads low when the fuel level gets to the point where the resistor is worn. Easiest way to check is to measure the resistance across the two sensor wires from under the car - infinite resistance/open circuit = dead sender. To check the gauge end, use a variable resistance across the car end and watch the gauge - not sure of what resistance should be for acorresponding gauge reading. =>Shop manual.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    My VS series 2 Exec shows the low fuel warning after I've used about 46 litres.....6 years ago the low fuel warning would not happen till I'd used 52 litres so this problem has got worse over the years and the reason it's happening is probably as Cheap6 outlines above. If you replace the sender you may end up with one just as bad from a wrecker and I'd imagine new they would cost quite a bit but I could be wrong.. It doesn't worry me as I'm used to it.
    Your fuel tank will hold 59 litres unless it has the long distance tank which holds 73 litres....maybe if it has the genuine factory towpack (not just a towbar) it has the larger tank.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    Quote Originally Posted by fonzo View Post
    whan the dash is on the odo screen (from memory) hold the set button till another screen is displyed, if its not the odo one it might be the next screen. what im getting at is there should be litres left in the tank and a few other things
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
    vs berlina s2
    Feb 2009
    VP Exec
    Jun 2005
    For future reference:
    276-290 ohms - empty
    94-100 ohms - half
    38-42 - full
    Avoid shorting the across the wires to the gauge i.e. 0 ohms when testing.
  1. Got me stumped - more fuel issues
    By moff_man in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-06-2010, 04:36 PM
  2. im stumped with this
    By launertic in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2010, 07:41 PM
  3. time for me to ask a question lol, im stumped on this one
    By CHEETR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-03-2009, 10:14 PM
  4. im stumped so very very stumped rac 4 mechanics a dyognostic and a dyno still nothing
    By smokey_dj in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-12-2006, 11:02 PM
  5. Steel Fuel Line Into Fuel Rail Question
    By VTSSDUDE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-09-2005, 09:50 PM
