Results 1 to 8 of 8
Thread: Vr Slips out of gear when accelerating
    jakewaze's Avatar
    jakewaze is offline Jakewaze
    VN Spack S1 Auto
    Nov 2008
    Default Vr Slips out of gear when accelerating
    Hi
    Just purchased a second hand Vr for $3700 today and noticed something I failed to pick up on the test drive http://forums.justcommodores.com.au/...milies/doh.gif
    When driving normally (like on the test drive) it shifts smoothly and quickly, but once the revs get higher under firm acceleration it just revs out until I back off the accelerator for a few seconds. I'm really annoyed at myself for not picking this up before hand.
    The car is immaculate in and out, drives very well and is on gas. Has 185000 ks and I am the 2nd owner. I am guessing the trans is on its way out, but just hoping for someone elses opinion.
    I was thinking of changing the fluid n filter this wkend to see if that fixes it but I may be wasting my money.
    Also would low fluid level cause this because I haven't checked it yet.
    Cheers in advance
    I may have broken the law, but that doesn't make it wrong!
    VS 5 Litre
    May 2010
    Yes low trans fluid would cause this defenitely, check it for sure as this is a plausible scenario. If its only done 185000 km's I can't see it having problems with the trans unless its been thrashed and not driven properly. Good luck.
    04 VY Exec SII
    Sep 2009
    Sydney West Side
    If it's not the transmission fluid your looking at around $600 to fix (including labor). My mate had the same problem with his VR Calais V6, He is a thrasher.
    jakewaze's Avatar
    VN Spack S1 Auto
    Nov 2008
    ah k cheers guys, cars gonna sit for a wk now coz im headin up north. I'll check this before i drive it next, Fingers crossed thats all it is
    jakewaze's Avatar
    VN Spack S1 Auto
    Nov 2008
    Ah k guys, just changed all the fluid and filter for the trans (shit of a job). the stuff that came out of it was shocking, the bottom of the pan was lined with sludge and the magnet had about 5mm of stuff on it.
    Now its slipping even worse (at around 3k rpm) so it looks like i'm up for another trans. I can't justify $2000 for a new one so looks like second it is.
    cheers for ya help
    VE series2 E3 HSV Clubby & VS Calais 5.0L
    Mar 2010
    Around WA
    You can pick up cheap trannys from TipTop wreckers in Bayswater. you should be able to find them in the phone book.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    sux man, sounds like she's rooted. Black sludge is a good sign its pretty much gone. Like u say, bit rich spending so much on a trans thats gonna be worth half the value of the car. A good second hand is usually the best way to go.
    Reaper
    jakewaze's Avatar
    VN Spack S1 Auto
    Nov 2008
    yeh gonna be looking into at the end of the week. I will still try to get the current suto checked out
  1. Slips out of gear.
    By Snowfox in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-04-2010, 07:32 PM
  2. Transmission slips on cold start
    By Candive in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-10-2009, 04:06 PM
  3. Ran my car last night, analyzing the time slips
    By PaRaDoX in forum V8 Development and Modification
    Last Post: 07-12-2007, 09:11 PM
  4. vp 5lt v8 auto slips gears when hot
    By hoon1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-11-2007, 03:11 PM
  5. Limited Slips Diffs Cone/plate
    By andrewro in forum General
    Last Post: 02-01-2006, 12:18 AM
