Results 1 to 10 of 10
Thread: Low compression when cold
    VS Commodores Series 2
    May 2010
    Default Low compression when cold
    I previously posted regarding a vibration problem that i was having when the engine was cold in my VS V6 commodore.
    I had a compression test done and found that when cold its about 90psi, but when hot its normal. I understand that this means that the rings are failing.
    I also understand that this will be expensive to fix, so how long can i get away with this problem without fixing for?
    Many thanks
    Holden VS Series II 1997 Ute - 5 Speed Manual
    Aug 2008
    May 2010
    It doesnt seem to be burning much oil at all. Havent had to top up in the last 6 months.
    VB SL/E
    Dec 2008
    Why compression test a cold motor?
    The test would not be accurate as the clearances have not taken up yet.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You should test for compression at normal operating temperature,..or near enough to......not cold.. If you are experiencing a vibration from the engine and suspect poor compression, I'd be looking more for one cylinder that had much lower compression than the others. If they are all more or less the same they should not cause vibration.
    May 2010
    Hi thanks for the replys.
    I took it into the mechanic with a vibration - when in drive and the engine is cold. I can feel it through the steering wheel and the dash rattles. After about 10 mins it goes away. Mechanic told me that he did a compression test, when cold and then hot. When cold he said it has low compression like 90 psi, and then when hot everything is normal, 180 or so. Should i listen to this guy? He said its piston rings, and probably need a rebuild.
    VB SL/E
    Dec 2008
    IMO find a new mechanic.
    I would be testing spark first, followed by fuel, compression at 180 on all cylinders at running temp sounds fine to me.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Dodgey lifter holding a valve open? Oil is thicker when cold.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    sticky ring. run a bottle of tune up crap from wynns or i prefer nurlon. cant hurt, i ran a complete 140000km treatment in my old v6 and it lasted for a 1000km trip with buggerd ballance shaft berings.
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    Not a bad idea.
    Maybe even some de carbonising spray through the intake.
  1. vn v6 compression
    By Jordo2 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-06-2009, 06:01 PM
  2. Compression
    By Reaper in forum V8 Development and Modification
    Last Post: 04-01-2008, 11:25 AM
  3. climate control blowing cold aircon on cold days
    By stackner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-12-2006, 03:24 PM
  4. what compression v6??
    By bec22 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-08-2006, 07:40 PM
  5. Too Much Compression?
    By Stranger in forum General
    Last Post: 26-02-2006, 02:02 PM
