Results 1 to 6 of 6
Thread: vs v8 distributer
    vs maloo
    Mar 2010
    Default vs v8 distributer
    Hey, can someone tell/show me how to fit my vs v8 distributer. I removed it when my engine was rebuilt and made no marks on it. Now I'm not sure of position it faces on motor. Is there a mark on distributer and block that helps alignment? Engine is set on top dead centre on no.1 cylinder. Some pic's would help me as well
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    if its on tdc on the compression stroke put the dizzy in any old way, just make sure the plug can reach the harness and the rotor button lines up with the terminal on dizzy cap for no-1 plug lead. then fire it up and put it in diagnostic mode and set timing to 12 degrees.
    this is all well and good so long as your balancer is still good and hasnt slipped on the keyway, if it has it will not give an accurate reading of tdc
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    vs maloo
    Mar 2010
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Ten degrees BTDC (in diagnostic mode) is the standard timing for a 304 V8.
    vs maloo
    Mar 2010
    VS 5L M5 VS 6L M6
    Apr 2009
    under your steering colunm there should be a rectangle shaped plug, 2 pins high and about 12 or so wide. bridge the pins between, hmm, 5 and 6 (i think) on the top row counting from the left
    Avoid cluey police
  1. Distributer - anyone had this problem
    By HSV.006 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-02-2010, 11:16 AM
  2. vh broken distributer
    By scolari in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-02-2006, 10:05 PM
