Results 1 to 9 of 9
Thread: Smokey when first started
    2010 SSV
    Jul 2005
    Default Smokey when first started
    Hey Guys
    My vr v8 is rather somey when first started, it goes away but when you crack it, after about 4000rpm it gets smokey again, any suggestions?
    VX II Calais LS1
    Jan 2010
    what colour is the smoke?
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost.
    2010 SSV
    Jul 2005
    VX II Calais LS1
    Jan 2010
    blue smoke is oil getting in, if it does it on start up and then clears i would say valve stem seals
    What oil are you using? try running a thicker oil and it will reduce it
    If it was worn rings i would think it would blow smoke all the time.
    2010 SSV
    Jul 2005
    Sweet, its due for a oil change soon ill give it a go. The thing runs like an animal so i didnt think it was anything major.
    Cheers for the advice champ!
    VX II Calais LS1
    Jan 2010
    20w50 is recommended for the 5.0, i use Penrite HPR30 in mine
    2010 SSV
    Jul 2005
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Bandit10 is on the money...but I'd add that in my experience if you hold the revs at say, 4000rpm for about 5 secs and it starts blowing blueish smoke then it will be bad rings....also will blow increasing amounts of smoke when flooring it as it goes thru the gears. If it's got more than 350km on it, I'd go for thicker oil for sure as it's a lot cheaper than a reco. Some of those 'stop smoke' products can work as well...it all depends on how long you want to keep the car and how much cash you want to throw at it.
    VY Ex-cop
    Mar 2006
    Quote Originally Posted by hako View Post
    thats it, i'd say rings are on the way out. idle for several minutes and tromp it in idle and it blows a huge puff of smoke then valve stems/seals are rooted but hold revs up and it blows then its stuffed rings. wont blow smoke all the time, only at higher revs if rings are on way out.
  1. [NSW] WTB: VS UTE smokey tail lights
    By Razor- in forum Swap / Wanted to Buy / Trade
    Last Post: 06-08-2009, 04:12 AM
  2. smokey, the suzuki rgv
    By naf33n in forum Miscellaneous
    Last Post: 22-04-2009, 06:49 AM
  3. Air-Con Smokey mist
    By kohan in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-01-2009, 08:27 AM
  4. smokey a/c
    By markie mark in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-11-2008, 06:51 PM
  5. Smokey VK
    By RayRay07 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-05-2008, 10:17 AM
