i have 97 vs wagon that keeps cutting out it will wind over but wont start again 4 about 15 20 mins it only seems 2 do it when driving it wont do it when idleing ive put a in new fuel pump/filter checked tank 4 water, replaced cas sensor ,checked codes. i found ants in the dfi connector cleaned it out put it back together now sounds like its running on five pistons. borrowed a mates dfi plate an coils runs better put still cuts out. i also found that 1 of the oxegen sensors was disconnected pluged it back in an still wont run. wat else could it be any help would be great i need 2 get it going to sell it urgently
i was about to say DFI... but if its not the DFI or a coil it could be something obvious like a dodgy plug or lead. or you still have a bad connection at the DFI plug or the bracket underneath. What codes are you getting ?
no codes only 12 could one plug lead shut the car down. my keys pretty dodgy if it was the bcm would the car still turn over ?
