Results 1 to 5 of 5
Thread: VR replacing radiator
    theHynes is offline The-Hynes
    VR Acclaim S1
    Sep 2009
    Eastern subs
    Default VR replacing radiator
    hey, ive had a look around, im not having much luck removing my radiator so i can replace it.
    any help would be excellent
    theHynes
    VR Caprice
    Dec 2005
    What sort of trouble are you having removing it, you have to remove it to replace it!
    VR Acclaim S1
    Sep 2009
    Eastern subs
    I just cant get it out lol, im pretty new to the whole car scene.
    I couldnt find a 'how to' in this section when i looked before
    theHynes
    Nov 2003
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I've got all 3 manuals - Haynes, Ellerys and Gregorys and I've found the Gregorys one to be the best...but that's just my opinion.
    Re removing the rad - just remove top and bottom hoses, remove bolts attaching fan and shroud to rad, remove transmission cooler lines and remove the spring clips on either side of the rad - squeeze them in....then just lift the radiator straight up.
  1. Replacing radiator hoses
    By Ron41 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2009, 05:44 AM
  2. Replacing VY Radiator
    By kiwiss5L in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-01-2009, 09:27 AM
  3. replacing the radiator, need help quick!!
    By PSYKO PHOENIX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-01-2009, 08:55 AM
  4. Replacing Radiator VS 1996
    By fourboys in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-02-2007, 09:43 PM
  5. Overheating since replacing new radiator
    By lovemyholden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-08-2005, 09:16 PM
