Results 1 to 2 of 2
Thread: code 81 vs auto
    vb sle
    Jan 2009
    adelaide
    Default code 81 vs auto
    ok this is a bit strange vs is coming up with code 81 2-3 shift solinoid but its sliping in first and there is no over drive strange?
    also the sticker on the side of the gear box that says 6hdd and 7hdd is not readable is there any other way of telling someone said somthing about 12 or 13 pin?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The 81 code will make the trans go into "Limp Home Mode" which is 3rd gear (meaning plenty of slip and no power) and reverse only....if you have a VS it will be a 6HDD or 7HDD....both will fit and both will have the same number of pins - the VR 4/5/HDD will not fit and has the different number of pins. I seem to remember the VS has an extra pin. The actual code is stamped somewhere on the trans but I'm not sure...maybe do a search.
  1. vs v6 auto code numbers??
    By trentahz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-10-2009, 05:28 PM
  2. Code 68 - Auto Trans Slippage ???
    By mattakaspeeedy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-09-2009, 03:03 PM
  3. auto trans error code help
    By stackner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-03-2009, 05:38 AM
  4. code 24 and gear box problems (auto)
    By jas98 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-02-2008, 03:48 PM
  5. VR 5.0L auto - error code 72
    By mess666 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-10-2005, 10:54 AM
