VS Commodore transmission has been slipping a little, checked transmission fluid and it was empty. Filled it up and car performs much better. Trouble is the fluid is leaking. I have attached some pics. Looks to be leaking at the transmission housing itself to my untrained eye...
could be either the where the cooler line bolt on or a front main seal
na thats defenatly ether a pan gasket or your dip stick tube the trans lines are above the leak and looks dry
id give it a filter and oil change and should be good
I'd say pan gasket, but it's a touch hard to say from those shots. Easy to fix, but a filthy job to do in your carport...
Thanks guys... there is already enough oil on the concrete from the leak... so off to the mechanic for this one methinks.
Sorry the pics were shit also...
