another question for u guys? will the power window set up from a vn work for my vs? like the motors and looms?
yes the motors should work fine, looms from doors to pillars should also. your VS being an exec, i doubt it would have half the wiring loom run along the sills or fuse terminals. you can run it indepentant if you run all new wiring. hope that makes sense
funny u say that, the fuse box has power windows and power seats. also the fuse relay is there too. will that mean the loom are there?
i got vn motors in my vr works fine, all bolted up perfect.
