Results 1 to 3 of 3
Thread: VR V8 Water Pump on way out?
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Default VR V8 Water Pump on way out?
    Lately she's been making a tickling/rattling noise, it only seems to be doing it when cold, as soon as the engine gets up to temp the sound disappears. Definitely isnt internal. Question is, is it the water pump on its way out or a bearing on one of the pulleys somewhere?
    The clutch driven fan shaft has a slight bit of freeplay but the water pump pulley itself seems pretty solid (as far as I can tell, I havent taken the belt off yet) there arent any major signs of leaking from the pump either. What can I do now to eliminate one or the other so I know whether to replace the pump or not? Cheers guys.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    vs commodore
    Oct 2009
    Tamworth NSW
    Id remove the drive belt and spin all the pulleys and water pump,alternator etc by hand, and feel for roughness in the bearings,also spin them quickly and listen to each of them for dry, noisy bearings which is a good sign that the lubricant has dried out and they probably wont last much longer.Do the same with the water pump.Also check its shaft for end and sideways play. I just replaced the idler pulley bearings and tensioner pulley bearing on my VSV6.They were noisy and a bit rough when I checked them.They were around $8 each from a bearing place.If theres any doubt about the water pumps condition,and its done a couple of years service, its best to just replace it .They are a fairly cheap part to replace anyway.
    Vee-ard's Avatar
    Jun 2009
    Bayswater, WA.
    Quote Originally Posted by Brett_jjj View Post
    Id remove the drive belt and spin all the pulleys and water pump,alternator etc by hand and feel for roughness in the bearings,also spin them quickly and listen to each of them for dry, noisy bearings which is a good sign that the lubricant has dried out and they probably wont last much longer.Do the same with the water pump.Also check its shaft for end and sideways play. I just replaced the idler pulley bearings and tensioner pulley bearing on my VSV6.They were noisy and a bit rough when I checked them.They were around $8 each from a bearing place.
    Thanks man I'll give it a shot.
    The hall of fame:
    ಠ_ಠ
  1. Vs water pump - Electric pump.
    By Lazin in forum V6 Development And Modification
    Last Post: 06-05-2011, 07:08 PM
  2. Water Temp/Water Pump?
    By Fred 96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-08-2010, 01:58 PM
  3. water disappearing - water pump - how to change?
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2008, 01:30 AM
  4. Davis Craig Electric water pump 80litre pump
    By HIROLLA in forum Parts And Other Items For Sale
    Last Post: 16-07-2008, 10:31 PM
  5. Water pump ?
    By Ron41 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-04-2007, 10:46 PM
