Just a quick questions guys, im looking at taking out the speed alert in my VS as i dont use it and want to use the space to put a voltmeter, but before i go ripping and hacking at it, how does it come out? Does it just pop out like the air vents do? or do i have to take off my dash to get at it from behind?
Cheers guys.
It will just lever out - even easier if you take the fascia off the dash cluster.
But you can pop it out from the front and unplug it.
and 3 Dangerous non ABS VN's
88greenvn has it there quite easy to take out..i tiook mine out but if ur putting a volt gauge in u gotta take the facia off any way to cut it
Cheers guys. I figured it would just pop out, but i just wanted to check. Thanks.
