Results 1 to 4 of 4
Thread: Mechanic Issues With VS Commodore
    VS Commodore Aclaim Series 2
    Jun 2010
    Mornington Peninsual
    Default Mechanic Issues With VS Commodore
    Hi Everyone
    First Time Poster so please be kind.
    I have a 1997 Holden Commodore VS Acclaim, and most recently it has started making some really bad noises.
    I have noticed that there is a whistling noise occassionally coming through what appears to be the front drivers side wheel area, this stops when I put my foot on the break, sometimes I dont hear it, but other times it will start up again.
    Today, I was driving and heard 2 backfires and the car is now jumping, I checked all the oils etc and everything seemed fine but I did notice some transmission fluid leaking around the radiator area, I have been topping it with transmission fluid but seems to have a leak, I have tried looking for where the leak actually is but can not find it anywhere.
    I would oboviously like to get this fixed and would love some general ideas, as it is my only car and can not afford a massive repair bill and can not get another car due to issues.
    vs commodore
    Sep 2009
    vic
    vs commodore
    Oct 2009
    Tamworth NSW
    I cant see how the transmission cooler lines would cause a whistling noise, or cause backfiring. If the transmission cooler lines near the radiator are leaking transmission fluid, then tighten or replace the rubber lines.Id check for any set error codes first up.Heres a link to a thread that shows you how to do this test.Its a simple test,easy to do,and very handy when trying to diagnose problems with these cars. ---Checking error codes VR/VS (Revised)---
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The whistling sound is possibly coming from the brake vacuum booster which runs on vacuum which is reduced slightly when you apply the brakes....check the large hose that attaches to the booster. If there is a major vacuum leak here, it may also cause backfiring by allowing air into the engine and upsetting the mixture.
    Re the oil leak - degrease the area with a $2 can of degreaser then start the engine and see exactly where it is leaking from.
    Welcome to the forum - you'll find answers to most problems here - some of the members can fix anything except a broken heart - all you've got to do is ask.
  1. VT commodore starting issues
    By cds in forum Electrical Wiring / Questions
    Last Post: 09-11-2010, 05:57 AM
  2. Steering shake issues, advice before going to mechanic?
    By mars6484 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 29-01-2010, 08:43 PM
  3. Bad Mechanic
    By waffles666 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-12-2009, 11:36 AM
  4. VS Commodore - Issues turning car on
    By killuminati in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-02-2006, 09:12 PM
  5. VK Commodore issues PLEASE HELP! LOL
    By sugrnspice in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-12-2005, 09:53 PM
