Results 1 to 8 of 8
Thread: 2 annoying problems...boot leak and aircon 1994 VR
    darcywr is offline I need mo money
    VR Commodore
    Jun 2010
    your mothers house
    Default 2 annoying problems...boot leak and aircon 1994 VR
    as in the title!
    my boot is drenched! only the bottom though, sides are dry as a bone! ANY suggestions at all..it smells very bad and moldy, my seals are fine, but whenever i open my boot there's a lot of condensation on the top of the boot :S
    and im pretty sure this may contribute to my humidity problem (and the smell)
    my aircon...i noticed it stuffed up after i put a new head unit in. Basically, very very little or no air comes out of demisters, back seat air vents, front, door, nothing. and also water sometimes leaks from under the driver side console near my feet.
    another concerning problem is that on a rare occasion (happened about 5 or so times in the past year) is that steam (definatly coolant smell) comes from the demisters...it used to come out of all vents but now its mainly demisters
    oh and my whole car fogs up REALLY bad...full on water dripping on the inside within 3 - 5 minutes
    any solutions would be greatly appriciated
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    u have bad blcokage and as for the boot when u open it does water dribble out if so its ur taillights ine bootlid
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Re the aircon problems - you have probably either knocked a vacuum line off the mode switch or crimped it or otherwise broken something when doing the head unit change...solution unfortunately is to go back and do it again. Re the boot - probably the rearmost side windows leaking water into the boot - very common problem and fix is like the headunit - remove, seal and replace. There are how-to's available in that section.
    Re the steam inside smelling of coolant - sounds like the heater is leaking which may or may not cost and arm and a leg to replace...do a search on that - dial in "heater leaking"
    TI3VOM's Avatar
    TI3VOM is offline VT V6 wanting 300RWHP
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    With the boot leaking if it's the same as the VT open it and check on the base of the boot under the tail lights to see if there are any bumps, if there is one on either side see if you can stick something in them.
    My VT used to gather water in the boot and when I opened it water would gush down into the base of the boot, someone told me that there are two drain holes in the boot that were puttied up by holden then painted over. I unplugged the holes and there is no more leaking water when I lift the boot up.
    Vr ss commodore
    Jun 2010
    I got that boot leak as well i think it is the small gap on top of the tall lights when i open my boot water comes pissing out that small hole
    vn executive s2 v6
    Jun 2008
    i had a similar leak in my vs boot, it turned out it was coming in under the bottom corners of the boot seal, i removed the rubber and filled it with a butel based sealer and refitted, mint now
    brandon17 is offline BD-76-SR
    SV6 vz, vt clubby =P
    Jan 2010
    newcastle
    i had a leak in my boot too, i found out i was leaking from the roof gutter above the rear quater pannel
    Jan 2010
    newcastle
    sorry, and also i found that some water was comming out of the boot tail light, because it was cracked, so i replaces the light and it doesnt leak anymore, a good way to see if the water is leaking from the roof is pour water on it, then look in the boot you should see the water comming down the side pannel or up near the top of the shock
  1. Annoying Hissing Noise (Vacuum Leak) in Dash Area
    By Deano3350 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-07-2010, 06:34 PM
  2. Aircon gas leak? VR
    By piker in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-05-2008, 11:57 PM
  3. aircon leak
    By quiksilver1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-01-2007, 07:15 AM
  4. I've finally fixed an annoying coolant leak V6 commy
    By auc05l in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-10-2006, 04:37 AM
  5. aircon leak
    By freddy69er in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-12-2005, 06:05 AM
