Results 1 to 10 of 10
Thread: Cold Start
    VZ SV8 5.7 A4
    Jan 2007
    Default Cold Start
    Have a VS SS and she is very hard to start when cold.
    No power loss, had a service 3 months ago.
    Once she starts seems to be fine but.
    (the battery keeps on going flat because of the amount of times she has to be turned over on cold start).
    If you turn her off and let it sit for a minute, it will start, its only on cold start up i have this issue.
    Any help much appreciated.
    Dec 2009
    Quote Originally Posted by BennyMac View Post
    Is the fuel pump running when you turn the key before the motor starts?
    1999 vs ute series 3
    Oct 2009
    maybe try turning the key to ignition but not kicking the car over, wait about 5 sec then try. gives your fuel pump more time to kick in
    Quote Originally Posted by Jonnii View Post
    yeah well it is a ute its not supposed to be about comfort
    http://forums.justcommodores.com.au/...rst-car-d.html <<< My 5sp vs ute
    VZ SV8 5.7 A4
    Jan 2007
    EDIT!!! Fuel Pump is fine!
    Fuel pump just keeps on running.....think i need to get it pressure tested.
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    VX II Calais LS1
    Jan 2010
    try swapping some relays around under the bonnet, cant remember 100% which relay it is but pretty sure its the EFI relay, if this fails power is taken direct from the oil pressure switch so the engine will only fire up once the oil pressure is raised slightly which will happen after the engine is cranked over by the starter a few times.
    Might not be your problem but worth a shot, switch it with a known working relay.
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost.
    VZ SV8 5.7 A4
    Jan 2007
    Went out yesterday and she started after about 10sec. Had a small fuel smell.
    When i turn her over, she just does not sound right.......
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    sounds like leaking injectors then, they leak into the chamber overnight making it hard to start when cold in the morning, but it needs quite a while to leak enough to make it hard to start.
    vs ss commodore
    Jan 2011
    victoria melb
    Had same trouble with my ss vs and changed ignition module and oil switch and seems okay now..prior to that changed injectors which didnt help
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Your battery is probably on it's last legs especially after going flat a few times plus all the extra cranking, so it may be time to threat the car to a new one - 660 cold crank amps is the way to go.
  1. cold start problem on VS V6
    By pomiedore vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-04-2010, 08:35 PM
  2. VT Hard Start on cold and sometimes hot
    By jazza15 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-04-2009, 06:59 PM
  3. cold start problem
    By green vr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-11-2007, 05:10 PM
  4. Hard to start when cold
    By jonh_vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-08-2006, 10:30 PM
  5. Can't start cold except for clutch start.
    By Holdfast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2005, 07:30 PM
