Yes its a straight swap as the diffs are the same, just different mounting points for shocks and bumpstops etc. Make sure he keeps the crown wheel and pinion gears as a mated pair (i.e. remove the crown wheel from his lsd centre and fit this to the open centre so the gears remain matched). May also need different shimming to set the correct gear mesh backlash.
sorry bout bringin this back up
i took my standard ute diff and an lsd diff (both matching diff gear numbers 05-75 i tihnk) to a mechanics.
they made me pay $200 to tell me that the centres would not be changable.
is that correct?
Mate Id contact these mechanics and tell them that you want some sort of refund or you will take it further,then if they wont be reasonable about it, Id be going to consumer affairs or MTA or whoever the governing body is for motor mechanics.Thats bullshit.Theres no way they should have charged you that much just to tell you they dont fit.Maybe charge you $50 -$75 for the trouble,,but not $200.
it was for the labour
i know its bullshit
but i dont really care for money, i just wanted to make my ute better..
i notice your in WA, which mechanic was it??
That's bull shit just tell ur mate to get a full spool, the centres are interchangable, as are IRS centres and solid, you where ripped off didnthey even take the diff housing off
its not the $$$$ ITS THE FACT someone is taking you for a ride>>> hay STAND UP FOR YASELF MAN( ya see if he does it to you and gets away with it? its easier for him to do it to the next bloke as well(and the next bloke may realy realy need his money?? SO GO BACK AND SAY SOMTHING(YOULL BE DOING IT FOR YOURSELF, AND ALSO for THE NEXT BLOKE INTO HIS WORKSHOP >YOULL HELP THE NEXT BLOKE OUT WITH OUT EVEN KNOWING IT (STOP THE ROT I SAY) nothing worse than RIP OF ARTIST (hope it dont happen to your again)
We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
