Results 1 to 9 of 9
Thread: how do i fix my door creak??
    vs calais
    Dec 2008
    Default how do i fix my door creak??
    my vs calais has developed a creak of the left rear door...
    its when i go over bumps and stuff, it makes a slight creak movement sound, as if the door slightly moves along the seals..
    i remember when i had my vr, it started doing this on a few doors,
    and now my vs has gotten it too..
    is there a way to fix this? and what is causing it?
    should i try and adjust the striker so the door closes more in?
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    more than likely its rubbing on the striker, adjust it up or down a little and see how you go
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
    RazzaCaine is offline Long Gone Now
    Mar 2010
    my car is also doing this, sorry for the dumb question but whats the striker and how do i adjust it??
    VX II Calais LS1
    Jan 2010
    the striker is where the door latches on to, its bolted to the B pillar, i had noise issues with my ss i ended up replacing all the door hinge pins and that fixed my issues, along with correctly adjusting the striker position
    you adjust the striker by loosening the 2 torx bolts holding it to the pillar, it will then move around think they are T35 bolts?
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost.
    Mar 2010
    vr stroker v6
    Jan 2009
    townsville qld
    Mar 2010
    ok well i had a look at my striker plate and it appeared to be lined up with the door latch fine. warning in advance, dumb questions coming..
    how do i tell if it needs adjusting up or down (without lining it up to the latch)?
    could there be another cause for the door creak besides the striker plate?
    it seems unlikely to be the striker plate in my case so im wondering what else it could be. thanks for the help guys and girls
    VX II Calais LS1
    Jan 2010
    nothing to do with lining up the striker, but open your door and tyr and lift it up and down to see if there is any play in the hinges if there is buy a new set of hinge pins.
    Worked for me.
    *uwishn* is offline Holden special vehicles
    vl walkinshaw(replica) vt clubsport r8
    Jul 2010
    sydney
    i reckon spray wd40 on the top and bottom hinge, and put some grease in the hinge.
    worked for my Datsun
  1. [NSW] FS: VT Headlights $50- bonnet protectors, door handles & door mirrors
    By 2Com in forum Parts And Other Items For Sale
    Last Post: 19-06-2010, 09:28 PM
  2. VX SS creak and clunk
    By SS-LS1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-07-2009, 02:18 AM
  3. [WA] Fs: Vt white drivers side door with window,door skin &mirror - $60 - perth
    By Timzo in forum Parts And Other Items For Sale
    Last Post: 12-01-2009, 07:59 PM
  4. front end creak
    By orangewagon in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-07-2005, 10:37 AM
  5. Creak When Opening Drivers Door On Vr Statesman
    By sik_vr_statesman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-07-2005, 02:01 AM
