Results 1 to 6 of 6
Thread: new bonnet problems?? cable or spring??
    vs ss commodore pantha mica
    Jan 2008
    bacchus marsh vic
    Question new bonnet problems?? cable or spring??
    hey, i have just changed my gf's bonnet on her vs, was peeling like crazy, and has fitted great but bonnet wont pop open, i can get a screw driver to prise the spring when closed and then opens, i only need to move spring a little and it pops, does the cable need adusting for the second hand bonnet or is it the spring?? cheers dan.
    VY Ex-cop
    Mar 2006
    Jan 2008
    bacchus marsh vic
    yeah i greased up the catch so im guessing need to make cable tighter, so guessing needs to be tightened from inside the cabbin some how, sure when i look at cabbin in car should see how to tighten??
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd also unscrew the bonnet spring pin one full turn - this reduces the tension on the spring clip allowing the cable to release the bonnet easier. See pix.
    Attached Thumbnails Attached Thumbnails new bonnet problems?? cable or spring??-bonpinscrew.jpg
    vz ss and vs statesman
    Mar 2009
    The pin on the bonnet may also have a groove in it try grinding it out or getting a new one may help. Also when the bonnet is popped pull the lever and make sure the spring where the pin goes in cleares the hole completely
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    Quote Originally Posted by trav_304 View Post
    loosen the screw clamping the cable to the radiator support and pull the cable to tension it a bit and retighten, id try that before you waste money on a new cable .
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
  1. Bonnet release cable snapped how do i open the bonnet
    By S-Pac_Sam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2010, 09:07 PM
  2. 95 lexcen bonnet cable will a VR cable fit?
    By Gazza2005au in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-06-2009, 04:19 PM
  3. How to change VS Bonnet spring?
    By pabeshky in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-03-2009, 08:56 AM
  4. bonnet cable issue
    By Goon in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-09-2007, 10:31 AM
  5. bonnet cable
    By zohpm in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-04-2007, 04:12 PM
