Results 1 to 8 of 8
Thread: oil pressure gauge
    Bagged vs caprice sII
    Sep 2007
    Newcastle
    Default oil pressure gauge
    Hey just bought some gauges for when my charger goes on installed them yesterday and having some trouble with my electronic oil pressure gauge i installed the t peice fitted everything up wired it up as per the instructions but when i turn the car on the needle just goes through the roof and maxes out over the 100psi i think it is, any suggestions why this is happening ? cheers
    VS S-Pack SII
    May 2008
    Without seeing the wiring digram for the gauge, i can only guess, there is an earth wire, and a signal wire going from the sender to the gauge, (as well as power and lighting wire/s)
    The gauge itself is nothing but an ohmmeter, made to measure resistance of the sender.
    A typical analog ohmmeter will have the needle fly to FULL SCALE DEFLECTION (in your case, 100 or more psi) when the earth wire touches the signal wire (Meaning ZERO resistance)
    Check 1:
    You havent wired the signal and earth wires backwards?
    Check 2:
    Perhaps you have a short somewhere on the signal wire? Or a faulty pressure sender unit.
    - To check the sender unit, measure its resistance with an mulitmeter, it should read something but NOT read ZERO .
    Check 3:
    take the signal wire off the sendor, and start the car (or a safer option is to put the ignition to ON but dont crank it) then, the gauge should NOT move. If this is the case. then refer "check 2"
    if it still dont work... let us know.
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    300psi oil pressure in your engine maybe?
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
    VE series2 E3 HSV Clubby & VS Calais 5.0L
    Mar 2010
    Around WA
    Have you put the right oil pressure switch in it as the one for running the dash light will not work.
    they usually go straight to max when the wrong type of switch is in there.
    Sep 2007
    Newcastle
    thanks for the input guys i tried re wiring it again today and still a no go, what it has is 5 wires from the gauge and 2 wores on the sender itself,
    gauge wires are
    red- 12v ignition
    white- 12v ignition
    green- sender wire
    black- ground
    orange- 12v dash lighting
    sender unit
    terminal 1- sender wire
    terminal 2-ground
    what i have done is since i dont want the gauge to turn on with the dash lights i ran the red white off the same source which is a 12v ignition source which runs through a switch and the orange off the battery i installed to control my airbag gauge light so i can turn the backlights on when i want to , i re ran a wire for the ground and sender unit today to clarify there is no shorts in my wires to the sender unit also tried changing the wires around to make sure it was not wired wrong from the factory, the only thing i can think of is a faulty sender unit , also checked that the unit was getting oil and the small hole going into the unit wasn't blocked, i will the test sender unit tommorow with my meter and see what i get
    Sep 2007
    Newcastle
    ok well tested everything today turns out
    white 12v ignition source- is the power for the backlight
    red 12v ignition source- is the power for the needle
    orange 12v dash light- got nfi gave it power took it off and nothing happened at all
    green goes to the sender
    connected up a set of wires today on the sender put my meter on (digital) no resistance across it turned engine on and still showed no resistance. me thinks its rooted?
    also when you turn the car on the needle goes above the max 140psi and just sits there im thinking the sender converts oil pressure into a resistance and causes a resistance between the power source for the needle and the gauge and should hopefully tell you pretty accurately what your oil pressure is is this correct if so im off to supercheap to get the sender replaced
    cheers
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    Sep 2007
    Newcastle
    sorted it got it replaced and it works kooooooooooooooool.
    cheers fellers
  1. Oil Pressure Gauge
    By My Car in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-01-2009, 10:15 AM
  2. Oil pressure gauge
    By sen8or in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-05-2007, 01:11 PM
  3. oil , air pressure gauge
    By Aryashahin in forum VY Holden Commodore (2002 - 2004)
    Last Post: 13-04-2006, 07:21 PM
  4. oil pressure gauge, oil pressure
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2005, 10:31 PM
  5. Oil Pressure gauge
    By Joshua in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-05-2005, 09:31 PM
