do i need to run better fuel set up than stock also injectors???
i have stock recon injector in my stroker there fine u will probably need to go oversize tb or twin tb as they dont suck enough air with the 60mm tb who is goin to tune it are u goin to get a come chip or get someone to rite one for ya as the come one is pretty tame and i have been told they not worth it as the are like 600 bucks
Talk to your engine builder who will be able to consider the engine as a whole and know what your end requirements would be. He will be able to calculate exactly what your injector flow will need to be and advise you if your tb/intake will be sufficient. If he can't then get another engine builder.
Reaper
