hey,
does anyone know if you can change diffs with a different diff? for example could a vr sedan fitted wit a live axle diff standard, coud it be changed to live axle lsd? or even a standard irs or irs lsd?
thanks in advanced
Live axel to IRS, forget it, completly different.
You can swap live axle centers for a LSD one, or the whole diff + axels.
diff, all you need to know
The Daily VN T5V6
355 VN GRP A REP
i recently just swapped my VN for a VS, the back diff is stuffed. jolts into gear so bad! it has LSD, i was wondering if i can change the diff and put the LSD onto the new diff from the old?
