Results 1 to 9 of 9
Thread: Intermittent VS V6 won't start
    Bud
    Bud is offline
    VS Executive S1
    May 2004
    Sidanee
    Exclamation Intermittent VS V6 won't start
    I have a 1995 VS V6 and lately it has a problem when I go to start it, the fuel pump doesn't run.
    It is an intermittent problem. When it won't start, the pump isn't getting 12V to that proves there is nothing wrong with the pump. Both sides of the fuel pump fuse has 12V, so the fuse is OK. The engine cranks fine and there is spark.
    I have swapped all the relays around, so it's not the relay. After a while it starts to work again.
    Is this a common problem and can someone offer any ideas?
    I have a workshop manual though it's an Ellerys and the wiring diagrams are next to useless. If I had a decent wiring diagram then I could probably trace the problem.
    Please help! My missus is starting to get the shits!
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Bud
    Bud is offline
    VS Executive S1
    May 2004
    Sidanee
    No - I said the pump isn't getting 12V. No I don't have an alarm/immobiliser in the car. It's all stock standard.
    bloodyricho's Avatar
    bloodyricho is offline Bloody Richo
    Vr V6 Equipe (hare) and VE SV6 (tortise)
    Dec 2009
    littleton nsw
    news flash u have imoblizer stock! it probable your key and when u stop laughing at this sugestion run your fault codes - there is "HOW TO" on here somewhere for that. see what codes u get but try the damn thing with your spare key.
    Making and running DUAL CHIPPED ECU SINCE 2010
    Bud
    Bud is offline
    VS Executive S1
    May 2004
    Sidanee
    No need to be rude mate. Yes I know it has one stock. OK I'll try the second key and check the codes. Didn't think of checking the codes. Thanks for the ideas
    Bud
    Bud is offline
    VS Executive S1
    May 2004
    Sidanee
    SV6
    Dec 2009
    A guy i new had a commodore forget what model, Motor would crank but not fully turn over, was going to rebuild the whole engine. Luckly he rang RACQ and got them to check it out, Replaced the battery in the key for the imbolizer, never had a problem since.
    Bud
    Bud is offline
    VS Executive S1
    May 2004
    Sidanee
    Hi guys,
    Some more info - It didn't start again this morning and I tried both keys - no difference. It seems to be temperature related. It started OK every day last week because it was overcast and wasn't as cold. Any ideas? It's obviously a bad connection somewhere. Where should I look first? It cranks over fine and has spark though the fuel pump doesn't prime.
    Bud
    Bud is offline
    VS Executive S1
    May 2004
    Sidanee
    Problem solved - it was the fuel pump
    It wouldn't start spinning due to worn bearings when very cold.
    All good now
  1. Intermittent start problem VS V6
    By Neile in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 01:02 PM
  2. hard to start: intermittent spark?
    By frustrated in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-12-2007, 04:05 PM
  3. VS Caprice hard start - intermittent problem
    By jonh_vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-06-2006, 09:19 PM
  4. Intermittent start...
    By Slow VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-06-2006, 07:49 PM
  5. Intermittent Start and run prob
    By Jaydub in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-06-2005, 08:51 PM
