feels slugish wen gets to high revs its not the auto thinking some thing to do with the fuel system car is standed any ideas
hello any 1
Fuel filter clean?
Fuel pump capable of supplying sufficient fuel @ high load? a pressure gauge and fittings is ~$50.
Is the cat.con. OK? Usually if it's blocked it's because it's melted after an engine ignition miss has resulted in the cat melting.
ok cool ill check it out.were s the best place to buy a fuel pressure gauge?
I bought one, with the fittings, from Pirtek. Need to tell them it's for use with fuel.
G'day could be the o2 sensor, mine still gave good fuel economy but no good top end was runnning too lean
