Results 1 to 6 of 6
Thread: Starting problem
    dumpedvs's Avatar
    dumpedvs is offline sheppa8
    Vx S
    Mar 2010
    Default Starting problem
    hey guys,
    please help, ive got a 95 v6 vs. I havnt started it in about a week and i went to start it today and it wouldnt even turn over. it just make a clicking sound. I dont think the battery is flat because the headunit would come on but it wouldnt make any sound? And i could hear the amp running.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd say that you have a flat battery. Just because the headunit comes on etc does not mean there is enough power to crank the engine. Turn your headilghts on - if they are yellow that will confirm a flat battery.
    dumpedvs's Avatar
    Vx S
    Mar 2010
    ok i will check that out, i would get my multimeter but its broken thanks anyway
    Dec 2009
    Quote Originally Posted by sheppa8 View Post
    A multimeter is no good unless you can measure the battery voltage while some one trys to crank the engine. what is happening is the battery is dropping voltage when it powers the starter motor as there is a lot of load, the solenoid drops out, voltage goes back up starter re-engages, voltage drops again and so on it goes. In this state things like your radio and tell tales etc will all work until you try to crank the engine.
    if you want to test the battery is needs to be load tested but 99% sure it's shagged. Go and buy a decent one like an Exide or Century for around $130 to $140steer clear of NRMA and other cheap ones.
    chrisdoesitbetter's Avatar
    chrisdoesitbetter is offline | → ³8°º™ ← |
    VR 3.8L
    May 2009
    it would use ten times the amount of power to crank the engine than it would to run your stereo
    dumpedvs's Avatar
    Vx S
    Mar 2010
    yeh i figured my battery was stuffed, Ive had to recharge it a few times now within a few months. And yes my alternator is working so its not that.
  1. VS starting problem
    By SSGEN-3 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2009, 01:25 PM
  2. VN starting problem
    By wes_v8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2009, 04:58 PM
  3. VT 5.0 starting problem
    By jb2020 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-08-2008, 11:22 PM
  4. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  5. starting problem
    By whatisnttakenalready in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-02-2007, 10:29 AM
