Results 1 to 2 of 2
Thread: manual wont go into gear properely
    vs s
    Sep 2009
    kellyville
    Default manual wont go into gear properely
    hey guys i have a vs v6 with a getrag gearbox and about 20mins ago wen i was driving i pulled up at the lights and when i went to put it into 1st it didnt go all the way in gear if you no what i mean like it felt like it is stopped by something from going all the way in when i take off in first i have to hold it in gear otherwise it pops out and it makes a clunk when i take off it does this in 1st 3rd and 5th only but like 2nd 4th and rverse are fine. does this mean that im up for a new gearbox or is there a way to fix it that anyone knows of?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    At a guess I'd say it's just the shift lever that's come loose or somehow out of adjustment - the clue is that 1st, 3rd and 5th are in the same plane....the lever is being prevented from moving forward to properly select these 3 gears. So I wouldn't panic. Someone else on this forum will no doubt give you an exact answer.
    Welcome to the forum also.
  1. Vn auto wont change out of 1st gear
    By Cameron in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-07-2008, 11:35 AM
  2. Plz help 4th gear auto wont work
    By mahooody in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2008, 01:29 PM
  3. auto wont go higher than second gear
    By V8commodore_chick in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-11-2007, 11:16 AM
  4. wont hold 2nd gear burnout
    By tbblitz in forum V6 Development And Modification
    Last Post: 18-03-2007, 08:45 PM
  5. trimatic wont stay in top gear
    By evargyb in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-10-2005, 06:49 PM
