Results 1 to 10 of 10
Thread: oxygen sensors
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Default oxygen sensors
    My vr has a 4 wire oxygen sensor that I want to replace( code 13 keeps coming up)....Ive looked on ebay and found a couple of 4 wire sensors to fit later models that have a different plug to the one I have....its no dramas fitting my plug IF they will work...any ideas? Also universal 4 wire oxygen with just wire ends ...will they work if I fit my old plug to it?
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    Yes that's fine, get bosch or delphi if you want it to last.
    One pair of wires is the earth and 12v for the heater, the other is the sensor voltage signal and earth.
    VS 5LT STATESMAN
    Sep 2008
    G'day Bosch recommend not to cut and join wires as they are shielded to give optimum performance mind you i was told this at a bosch school.
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    i had noticed the shielding on the bosch ones were very good and tuff, also the wire they use you can't solder, so i join mine with twists then heat shrink rated to high temp, but yeh i can see your point. I useually have to cut and do my own as 2 wire bosch ones are hard to find so i get the 4 wire and dont hookup the heater.
    Can't say ive had any problems though doing it this way, they last much longer than the cheap ones still.
    vs calais
    Dec 2008
    Hi mate, how much was the ones on ebay? i might be able to get you a genuine one for cheaper
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    vs calais
    Dec 2008
    Quote Originally Posted by The1 View Post
    last time i bought a set of genuine bosch they were $49 each
    when was that?
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    Nov 2003
    northside brisbane
    Quote Originally Posted by admir87 View Post
    buy it now genuine $69 4 wire but to fit a later model v6
    universal 4 wire 30 bucks
    triton universal 4 wire 99 cents atm
    bosch 4 wire with vs/t plug $55
    another 4 wire universal $54
    4 wire bosch to fit later model 48
    which one?
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    This is what im using now, last set lasted me 40,000 but with a leaking intake gaskets, normally they last 50,000 to 80,000
  1. [Ecotec] Oxygen Sensors.
    By one_and_only2004 in forum V6 Development And Modification
    Last Post: 28-02-2010, 09:35 PM
  2. L.P.G and oxygen sensors
    By mattyr82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-04-2008, 09:12 PM
  3. oxygen sensors
    By mahooody in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-11-2006, 09:32 PM
  4. Oxygen Sensors
    By wetwork65 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-06-2006, 10:16 PM
  5. Oxygen Sensors VS V6
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-03-2006, 06:25 PM
