Results 1 to 15 of 15
Thread: stage 2 rebuilt auto
    FG XR6 TURBO /RIP VT II LS1 Clubby, VR Commodore S
    Mar 2009
    Default stage 2 rebuilt auto
    hi guys
    i was wondering if anyone knows any good auto mechs in Victoria in south eastern suburbs possibly or near Melbourne
    i want to get a rebuilt stage 2 auto for an upcoming turbo build
    maybe a little advice on what i should be putting in it etc
    would be appreciated thanks guys
    also what do people think about billet 2nd and 4th gear servos ? apparently it shifts harder then covette servos ?
    thanks
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    Wholesale Automatic Transmissions
    ask this mob, my mate got a stock std vp trans over nighted when he got stuck and they came through with the goods, they go world wide and do race trans....
    should add it was a brand new one not reco for 1100
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    I had my vs gearbox built at RVO Automatics in Dandenong. They reckon it'll handle 350hp no problems, and if it breaks in 12 months they rebuild it free. 15 months on and mine hasnt had a problem, even after the flogging I've given it
    vs executive s1/ vz berlina
    Mar 2008
    If you gonna put turbo, my advice would be a high stall converter, after market HD sun shell, set of metal piston with molded seal for the cylinder, 3&4 high temp. friction clucth ( this set of friction is one sided only and no need to put the old friction plate)
    Mar 2009
    thanks for all the input guys, ill definitely give that wholesale place a look sounds insane
    and RVO since its close to me,
    Philthy what exactly did you do to your transmission to get it 350hp worthy thanks
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    I can vouch for the billet servos, had one in my VR shifted SO HARD.
    So much more surface area for the auto shift with compared to the corvette servos, don't settle for them get a billet you won't regret it.
    edit: hopefully i'll have mine back soon buying back off the guy i sold my vr too
    Mar 2009
    thanks for that nathanwright, after hearing that im definitely getting billets
    i saw them on ebay just to get rough idea there around the $180 mark is that around how much they normally cost ?
    goodluck with getting your vr back
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    180 sounds like a good price, i bought mine secondhand off my auto mechanic for 150.
    not getting the VR back, just the servo out of the trans cos he's converting it to manual.
    man the boost you get on shift is awesome lol.
    Mar 2009
    Quote Originally Posted by nathanwright View Post
    lol nice cant wait to get it all done, should be even better with the added boost from my turbo setup coming after my auto rebuild
    does anyone know how much a fully rebuilt stage 2 auto costs around ? 2000-3000 mark ?
    VP Exec
    Jun 2005
    There are two aspects to the 4L60E trans.: the "hard parts", like stronger rotating bits and friction surfaces, and the shift hydraulics. The PCM on the shift side has to be altered too, otherwise it will be trying to "correct" the mechanical changes. You can still have it shift as soft as a standard car at light throttle and shift "hard"/fast at full throttle but it needs to the PCM to be reprogrammed to do it.
    Mar 2009
    thanks cheap 6 i didnt know that, i was wondering to myself if it was always going to shift hard at even light throttle, that cleared that up, so PCM has to be reprogrammed, do they usually do that or is that sumthing i have to do outside of the whole build ?
    Philthy's Avatar
    Aug 2005
    Quote Originally Posted by YILDI2 View Post
    I've lost the sheet with exactly what they did, but it was a pretty standard rebuild + strengthen from what I gather. I had the full rebuild and shift kit for under $2g, and a hi-stall converter was a couple hundred extra which I wish I had gotten
    Mar 2009
    sorry i took so long to get back to this thread
    but i called RVO auto, told him i needed a rebuild for a turbo conversion
    he quoted me $2600 for a rebuild with whatever shift kit and said would handle 300kw at the wheels 2 years gurantee ( he said flog it as much as you want lol was the funniest conversation over the fone )
    sounds good but the bit were he claims to make all the parts himself got me a bit worried i asked him that i want billet servos his like mate i dont get that sort of stuff i make it myself, he said that there rubbish lol and also that hes developed his own shift kit i think he recommended at stage 3 kit
    anyways let me know if its good or not before i go get it tommorrow, im gunna give him a rooted auto that he can rebuild and im gunna pull my one out and sell it
    VS L67 Statesman
    Oct 2006
    Melbourne, VIC
    Dave from RVO knows his stuff. What other place backs up their boxes with warranties like that
    I've got one of their boxes behind my L67 and it's handled it fine. The only thing I have found with RVO is that the converters they supply tend to be a bit loose/high, but if it's not right they will restall it.
  15. #15
    Mar 2009
    i got my auto a week ago
    and its F*%^N mad
    goes hard, changing gears from 1st to 2nd get wheelspin ( stage 3 fully manulised )
    your right dave does know his shit
    i might even get him to turbo my car
    he qutoed me around 300rwkw with 10 pounds
    the raptor boys said even 270rwkw is impossible on 10 pounds
    can anyone clear this up and tell me if its possible ?
  1. [SA] Rebuilt 253 And Auto Sell/Swap offers please asap
    By TRICKEDUP in forum Parts And Other Items For Sale
    Last Post: 05-06-2009, 12:11 PM
  2. where to get a Rebuilt V6 Auto ?
    By Mates85 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2009, 11:22 PM
  3. Anyone rebuilt a 4L60E auto at home ?
    By greenacc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2009, 03:35 PM
  4. rebuilt engine, auto problems
    By Zuicider in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-03-2008, 11:09 PM
  5. anyone rebuilt an auto trans before?
    By jules in forum General
    Last Post: 13-07-2006, 10:23 AM
