hey guys can anyone advise me of the easiest bolt on brake upgrade for my vs stock brakes just dont cut it am looking for soething reasonably cheap and easy and brakes that are readily available
also how the hell do you remove door lock button on door to remove door card without wrecking door card trim around lock
plenty of threads on vt brake upgrade for vs do a search.
If you mean the central locking up down knob take the red strip off and there is a screw behind.
heythanks the1 cheers mate will do search
cheep brakes would be to do pads and machine roaters, bleed brakes etc, or the other end of the scale would be the vt upgrade kit.
with the door lock, the red bit in the snib needs to come out, slide a small screw driver in the side of the red bit and sort a move it toward the opposite end of the snib. the red bit is a locking tab on to the metal rod.
Originally Posted by Adam Savage (mythbusters)
