Results 1 to 9 of 9
Thread: Tyring to remove the front rotors on my VS! ;( - How to?
    VS-II Esteem
    Apr 2010
    Tasmania
    Default Tyring to remove the front rotors on my VS! ;( - How to?
    Hey fellas!,
    I'm currently in the process of replacing my front rotors and brake pads. I've removed the calipers and can't seem to take the rotors off? I've sprayed into the area with some WD40 and given them a light tap but to no avail. I've never done these before so can someone tell me how to go about this?
    Cheers Fellas!
    Dec 2009
    you can tap them from behind with a hammer while you rotate them. don't hit them too hard as you may bugger the bearings. If that doesn't work you can apply some gentle heat to the rotor around the centre of the hub inside of the wheel studs, and I mean gentle and the rotor will expand and come off as it's probably rusted to the part of the hub that sticks out in the centre.
    VS-II Esteem
    Apr 2010
    Tasmania
    Hey Fellas,
    I figured it out! I noticed there were 3 small holes with thread in it. Found some old 202 water pump bolts and they fitted the thread perfectly. Would a couple of them in and 30 seconds later the rotors were off!
    Cheers!
    DLFHUB666's Avatar
    DLFHUB666 is offline Got Milk ???
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    rubber mallet an go to town on it i just did the front on my vx an i had to get nasty with it
    DLFHUB666's Avatar
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    VS-II Esteem
    Apr 2010
    Tasmania
    I tell ya', just getting the tyres off took some major work. The tyres haven't been off for many years now, and it's like the rust had bonded to the back of the rims or something. Had to get in there with a shit-load of wd40 and let it soak just to take them off.
    VS-II Esteem
    Apr 2010
    Tasmania
    hey DFLHUB666,
    That's what worries me with the new cheapie cross-drilled and slotted rotors that will be going on. They don't have the threaded holes, so when they will be due in the future I might be in for some trouble.
    VX II Calais LS1
    Jan 2010
    Quote Originally Posted by slayer208 View Post
    hey DFLHUB666,
    put some copper grease on your hubs and they will come off easy next time.
    Quote Originally Posted by destiny View Post
    so im gonna need a supercharger? fck that ruined my dreams, oh well, it will b easyier to get a turbo then i dont have to pay for the boost.
    VP Exec
    Jun 2005
    Clean up the hubs with a wire brush before you put the new discs on and apply a thin coat of anti-seize eg. Copaslip between the disc and hub and the wheel centre and the hub.
    The trick with getting discs off is to hit them from the outside i.e. towards the centre of the car while rotating the disc/hub. They will pivot on the hub and it's easier than trying to hit from behind.
  1. Where to get HSV front rotors?
    By lockmac in forum VY Holden Commodore (2002 - 2004)
    Last Post: 09-11-2009, 07:43 AM
  2. [QLD] (FS) DBA GOLD Slotted/Drilled Front Rotors & Rear Standard Rotors
    By markc3012 in forum Parts And Other Items For Sale
    Last Post: 26-09-2009, 10:44 AM
  3. help!! front disk rotors
    By sudzy! in forum General Discussion
    Last Post: 05-09-2008, 07:30 PM
  4. Front rotors stuck
    By Dayvo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-08-2007, 06:41 PM
  5. Front rotors and shockies.
    By DANNY8 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-04-2007, 11:11 PM
